Turbo Question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-09-2014, 10:16 AM Thread Starter
vick97psd's Avatar
Turbo Question
Ok there might be info out there on the question I'm going to ask but I haven't found enough on the topic for me to go try it out.
My question has to do with the turbo and difference between the super duty and Obs. I want to know what if any difference between the 2 center sections other than the mounting bolts,(Obs having 4 bolts that go in from underneath the pedestal and the super duty having 2 going from the top of the turbo.)
I'm curious cause if the turbine and compressor housing from Obs turbo will bolt to.the super duty turbo i wanna swap out the center section making the turbo easier removal and installation when I need to pull it.
Thanks in advance for any and all help.
97 OBS F-350 cclb 4x4 7.3L CCV mod w/filter, 6637 intake, 3" DP, 4" straight exhaust, Banks I/C, Glow Shift boost, pyro, trans, fuel pressure. gauges, diy e-fuel, Racer X eagle t/c, Derale cooler pan, inline spin-on trans filter, IDP bellowed up-pipes
Soon to come- HPOP, Racer X valve body, Swamps injectors, Swmaps 6pos chip, Swamps IDM, haven't decided on turbo yet
2010 Supercrew FX2 Wifes ride
vick97psd is offline
post #2 of 2 Old 07-09-2014, 11:06 AM
erics diesel's Avatar
I believe that the only superduty turbo that will work for that idea is an early 99 van turbo. There is a member on here who did it
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
