Electronic Flasher Question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-07-2014, 06:27 PM Thread Starter
I currently have this flasher unit:
CF12ANL-01 LED Bulb Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs
I want the clicking sound however so I was thinking of getting this one:
http://www.superbrightleds.com/morei...asher/782/836/
The second one says it's for European cars. The only difference I see between the two is the ground prong. Seems to me I could use this one and just ground the third prong somewhere under the dash.
Thoughts?
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 6 Old 07-07-2014, 08:59 PM
Quoted: 86 Post(s)
I dont have much experience with these since i just ordered a new flasher from rock auto. There was an electric anf a mechanical. I didnt know the difference besides mine being the mechanical looking one. Ill let you know when mine comes in and how it works and when I get on a computer i'll get the part #'s and links.
White95f250 is offline
The Following User Says Thank You to White95f250 For This Useful Post:
mikeallenbrown (07-08-2014)
post #3 of 6 Old 07-08-2014, 05:32 AM
Quoted: 53 Post(s)
With the third male terminal, three-terminal flashers won't plug into the sockets on the fuse box.
Two-terminal version of the above flasher: CF12ANL-01 LED Bulb Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs . You'll need one for the directionals and one for the emergencies.
madpogue is offline
post #4 of 6 Old 07-08-2014, 05:41 AM
Quoted: 86 Post(s)
I am replacing the round one in the fuse panel in the dash to the lower left of the steering wheel. It is the 2 prong mechanical one and as said above the third prong won't work. One I am replacing is a Tridon EL12. The one from rock auto is the same and I am replacing mine because it is intermittent and its about time for a new one.
post #5 of 6 Old 07-08-2014, 05:52 AM
Quoted: 53 Post(s)
^^^^ You'll still need the second one to replace the one behind that one on the other side of the panel; one is for the directionals and one is for the emergencies.
madpogue is offline
post #6 of 6 Old 07-08-2014, 05:53 AM
Quoted: 86 Post(s)
Ah ok, thanks.
