Changing mechanical fuel pump in valley - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2014, 05:44 PM Thread Starter
What's involved in changing this pump? I have a friend with an international box van. Budget truck 24 or 28 foot. Lift up front end. He needs a mechanical pump installed. Been a while since I screwed with one. What do I need to do? What tools? It's at a storage place. He can't get it to me. I have to travel to do a road sue repair.
Thx for any info
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 7 Old 07-07-2014, 06:05 PM
RedneckYankee's Avatar
You can get it out without removing the turbo however, getting the banjo bolt back in is a PITA. I had to get my 12yr old daughter to get bolt started back into the new fuel pump. If I remember correctly the banjo bolt is 1 1/4" box end wrench will get it off. I first removed the fuel filter bowl and then the fuel pump. I loosened pump hold down bolts and tapped pump loose then bumped starter till pump pushed up so as to not loose the plunger. Wasn't difficult just hard getting banjo bolt back in. If you have small hands or someone with small hands that can get bolt started it's not bad. Good luck hope this helps
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #3 of 7 Old 07-07-2014, 06:43 PM Thread Starter
What's up with the plunger? I have been in there before to change the little hoses, the short ones. It's been a while. Will something fly out? Does fuel bowl have to cone out? If so, do I need new seals? Trying to have all necessary parts. It's an hour drive to this truck. It's out in an old storage place in middle of no where. Tough to get more parts.
Can I do something with electric pump and bypass it? Can I rig done thing easy to get it home?
melmount is offline
post #4 of 7 Old 07-07-2014, 06:46 PM Thread Starter
My bad, this is pre powerstroke. It's older idi. He just called me. Where's it at?
melmount is offline
post #5 of 7 Old 07-07-2014, 08:52 PM
Don't know anything about the IDI engine
post #6 of 7 Old 07-07-2014, 08:56 PM
On the powerstroke 7.3 the plunger for the fuel pump is in the bottom of the pump facing down inside the engine. If the pump lobe is down the plunger if loose in the pump could drop inside engine. If your lucky it will end up in the oil pan. I always have Murphy waiting in the wings for me when I decide to do something "easy and simple"
David
Dash Boss Monitor
Blue Spring Upgrade
No Kitty
4" Straight piped
Studded
1996 F250 XCLB 4x4
post #7 of 7 Old 07-08-2014, 04:44 AM
erics diesel's Avatar
If its an Idi the pump is on the lower passenger side of the motor
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
