Front brakes - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-07-2014, 04:35 PM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Front brakes
Front left locks up mainly when I start out in the morning, the steel line feeds that brake first, so most likely getting the pressure before the rest, thinking of putting a tee somewhere in the middle of the front line to distribute the pressure. Anyone else have this issue, or moved the line from the left front hose to another location?
dirtcrew51m is offline
post #2 of 10 Old 07-07-2014, 06:57 PM
PSMstroker's Avatar
Have you done brakes to the truck before and have you ever replaced the calipers.
96 power stroke
extended cab long bed
4 wheel drive
4" Diamond Eye Performance exhaust system
Auto Meter sport comp Pyro, tranny, and boots
Edge EZ
S&B intake
FPR shim
Banks transcomand
Banks ottamind tuner
150 DBA 150psi train horns
5 gallon air tank and Viair 480c compressor
2.5" tuff country lift kit
285/75/16 goodyear wrangler duratracs
E4OD automatic that is fresh.
PSMstroker is offline
post #3 of 10 Old 07-08-2014, 08:49 AM
dazed01's Avatar
The brakes did not lock up like that when the truck came from the factory. Something is wrong with the braking system that re-engineering it probably won't help.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #4 of 10 Old 07-08-2014, 10:55 AM
Quoted: 2 Post(s)
Yeah... fix the problem, don't just bandaid the symptoms.
One thing to consider is that brake lines often can fail internally such that a flap of rubber is hanging out forming a bit of a check valve. If your right line was not letting pressure through fully, it could cause this. Otherwise, sticking calipers or sticking caliper slide bolts could make problems along these lines.
It's probably as good a time as any to go through, replace your brake lines (time for shiny new SS ones!), make sure the calipers are moving properly and sliding on their slides properly, etc. Don't mess around with your brakes - fix them right!
Syonyk is offline
post #5 of 10 Old 07-08-2014, 11:40 AM
erics diesel's Avatar
If your going to replace the hard lines I would get copper nickel lines that will not rust
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #6 of 10 Old 07-08-2014, 02:25 PM Thread Starter
Quoted: 6 Post(s)
New pads, rotors, calipers, rubber hoses, I did some more looking and the previous owner replaced the front lines, instead of doing it right, he joined them with pieces, and there are some loops in the line most likely loosing efficiency. The previous idiot half a$$ed the truck. A year later and I am still finding stuff wrong. I am on vacation next week I am going to replace all of the lines along with the front ball joints.
post #7 of 10 Old 07-08-2014, 03:09 PM
PSMstroker's Avatar
Wow that's really nice of him to put his life and others in danger of doing shady mechanic work wait I mean half a$$. What's next he puts gas in the fuel tank to save money on fill ups or did he put a GMB water pump on the motor from schucks!!!! I tell you some people don't take pride in there own work on their on rigs. I see it everyday in the heavy equipment world. Some moron half a$$ed a job by running hydraulic lines and now they rubbed through and blew. Instead of taking your time to do it right the first time they cut corners. Hope you can find it all before its too late bro.
96 power stroke
4 wheel drive
Edge EZ
S&B intake
FPR shim
Banks transcomand
post #8 of 10 Old 07-08-2014, 03:35 PM
Quoted: 2 Post(s)
At least my truck was shop maintained by the previous owner... I still find occasional things that they messed up, but it's pretty solid.
Are you going to go with standard pads/rotors, or are you going to take the excuse to upgrade to the Cryo Powerslots and Hawk pads that should last significantly longer than the stock setup?
Syonyk is offline
post #9 of 10 Old 07-09-2014, 04:02 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
powerslot rotors and hawk pads are worth it
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #10 of 10 Old 07-09-2014, 01:37 PM Thread Starter
Quoted: 6 Post(s)
I knew what the truck was, and the condition it was in so nothing surprises me. Fuel leaks, trans line leaks, water leaks, tires leaked, the only good thing the guy did was to put in a full aluminum radiator.
