My powerstroke took a dive for the worst today... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-06-2014, 07:07 PM Thread Starter
After 306,000 miles the unthinkable happened Friday my compressor wheel in my turbo blew apart running at about 2300 rpm where's the best place to get a 7.3 rebuilt in north Texas?
Thanks,
Steven.
TripleP is offline
post #2 of 11 Old 07-06-2014, 07:37 PM
Quoted: 21 Post(s)
I'd buy a good used one instead man, a rebuild is gonna be thousands.
I see 7.3s fairly often for less than $1000. The rebuild kit for a 7.3 on rockauto is well over $1500 with shipping.
Syndicated_cdn is offline
post #3 of 11 Old 07-06-2014, 08:13 PM Thread Starter
It's at the mechanics house right now and he has the head off and I have compressor wheel all in my cylinder heads valves everywhere I know for sure it doesn't run and he's talking total rebuild if he sent it off to be upwards of 4-5 thousand dollars not including his labor of pulling out and putting in... Maybe this truck will just be another obs you see sitting out in a field will post a picture in a minute
TripleP is offline
post #4 of 11 Old 07-06-2014, 08:26 PM Thread Starter
Here she was all shined up before I rolled out Friday
TripleP is offline
post #5 of 11 Old 07-07-2014, 08:32 AM
boozinag's Avatar
Twisted metal in Salado, but that central Texas. I agree with the above replace the engine, rebuild yours on your sparetime to be a BEAST of a motor. AND/OR find a 444 (7.3) from an international 4xxx series with the allison tranny and put that in there.
boozinag is offline
post #6 of 11 Old 07-07-2014, 08:48 AM
PhilMac's Avatar
I am in my rebuild replace about $3500. Prolly got another $500 to go. Mine slung a rod and it put a hole in the block. everything else was beautiful on the inside. I found a low mileage 7.3 (126K) for $1,500. this was by far the cheapest thing I saw. other 7.3 with that kind of mileage ive seen from $3k-6k. They arent cheap. I couldn't make myself put in a "good used" motor with out cracking it open. I am doing a budget rebuild; new bearings, gaskets, injector cups, up pipes, having the block honed and the crank polished. If my block hadn't been destroyed I could have rebuilt it for about 2-2500.
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
'77 F-250 Highboy 460ci SCLB C6 4x4
Rebuilt 460ci
Comp Cam, P&P DOVE-C Heads, Holley 770cfm
Flat top pistons. 10.5:1ish compression
PhilMac is offline
post #7 of 11 Old 07-07-2014, 09:34 AM Thread Starter
Well just got off the phone with my mechanic he said he had it apart last night rods and pistons out, looks like I'll be getting my heads and valves re worked because my cylinder walls aren't scratched he said I'm going to need new injectors so looks like this is where I get to have a little fun going with 50cc injectors a Garrett gtp38r ball bearing turbo and going to have my head ported and polished and my mechanic is going to help me put some tunes on a chip
TripleP is offline
post #8 of 11 Old 07-07-2014, 09:46 AM
leojr's Avatar
Quoted: 4 Post(s)
Plus one on the buy a used one unless your budget allows having it rebuilt. They pop up on this and other forums local to North Texas and Craigslist. I can help keep an eye out if it helps.
Edited to add: Just saw your post…that's good news!
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #9 of 11 Old 07-07-2014, 02:04 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
cummins swap time
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #10 of 11 Old 07-07-2014, 07:32 PM
PSMstroker's Avatar
Did you try calling Bill Hewitt at powerstroke help. He should have a lot of spare 7.3 parts. I've bought 6.0 parts from him when I was overhauling 6.0 motors on the side. He's a stand up guy and he will work with you.
96 power stroke
extended cab long bed
4 wheel drive
4" Diamond Eye Performance exhaust system
Auto Meter sport comp Pyro, tranny, and boots
Edge EZ
S&B intake
FPR shim
Banks transcomand
Banks ottamind tuner
150 DBA 150psi train horns
5 gallon air tank and Viair 480c compressor
2.5" tuff country lift kit
285/75/16 goodyear wrangler duratracs
E4OD automatic that is fresh.
PSMstroker is offline
