DE down Pipe insulation - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-05-2014, 04:40 PM Thread Starter
Has anyone put header wrap or another form of insulation around their downpipe? Sure seems mighty close to Auto tranny and cooler lines. I am looking for ideas of what others have done. Just complete a complete DE turbo back with muffler, love the sound it produces. Just worried about the transmission heat issues though.
richardi503 is offline
post #2 of 11 Old 07-05-2014, 05:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Frank (Ol blue 97) had his down pipe ceramic coated
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 07-05-2014, 05:44 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
I used the old shielding off my old stock downpipe.
dirtcrew51m is offline
post #4 of 11 Old 07-05-2014, 07:10 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Not happy with it tho. When I do it again I'm gonna do a stainless pipe with a heat shroud.
The heat tape or "header wrap" can rust a pipe out quicker then flies on ****. Nascar actually banned it I hear.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 11 Old 07-06-2014, 06:11 AM
c69ss396's Avatar
Header wrap is bad, it trap in moisture and causes the pipes to rust out extremely fast. I recommend Second Skin Products. This works greats NOISE & VIBRATION COATINGS - Firewall - Liquid Thermal Barrier - Second Skin Audio
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 11 Old 07-06-2014, 11:23 AM
ol_Blue97's Avatar
I don't think you posted that to spray on the DP, but just putting it out there. Its not rated for the temp a DP needs
FRANK THE TANK
post #7 of 11 Old 07-06-2014, 11:28 AM
erics diesel's Avatar
Whats wrong with the ceramic coating on your dp Frank?
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #8 of 11 Old 07-06-2014, 01:42 PM
c69ss396's Avatar
I didn't, I sprayed my firewall, it cut the engine noise and heat in half...
c69ss396 is offline
post #9 of 11 Old 07-06-2014, 02:44 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Subscribed. My bronco is already hot on the floor/firewall with the gas motor and spray bed liner, I am worried when it gets the power stroke
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 11 Old 07-06-2014, 04:58 PM
ol_Blue97's Avatar
Rusting already..... bad job was done. All the good shops around me don't do it because it's not profitable or the cost will be too high. Should have just went with the stainless TYMAR down pipe.
FRANK THE TANK
