cab mount bolt replacement? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-05-2014, 07:41 AM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I'm replacing the cab bushings but I need new bolts I was thinking grade 8 industrial bolts ? What does every one else use when there old hardware is bad on the cab mount bolts.
bdemutis is offline
post #2 of 14 Old 07-05-2014, 09:40 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
NO, not grade 8. These bolts need to flex. Grade 8 will snap. Get grade 5 or get OEM bolts
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 14 Old 07-05-2014, 10:57 AM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I tried getting OEM Ford can't get me them and I can't find them online nor can wait. The guy at ford said grade 8 but true they have no flex. OK so grade 5 bolts and a bolt sleeve.
bdemutis is offline
post #4 of 14 Old 07-05-2014, 12:07 PM
Quoted: 4 Post(s)
Bolt sleeve?
OE bolts
As much as I hate LMC
Truck Parts and Truck Accessories
post #5 of 14 Old 07-05-2014, 01:19 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
Bolt sleeve?
OE bolts
Yea the washer that goes on the bottom has like a flare on top so it goes in the bottom bushing.
bdemutis is offline
post #6 of 14 Old 07-05-2014, 02:57 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I guess you would call it the retainer its a washer that goes on the bottom mount bushing.
bdemutis is offline
post #7 of 14 Old 07-05-2014, 03:47 PM
Quoted: 4 Post(s)
Yeah steel body bushing/retainer. The top and bottom "retainers" slide into each other
post #8 of 14 Old 07-05-2014, 07:52 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
Could I substitute the retainers with something instead of paying 25 a retainer?
Edit: Also on the truck diaphragm I see no upper retainer but still for $75 just for a nut welded to a washer welded to a sleeve I think I can make that at home for less money and a few tack welds.
Ok on summit racing I see a energy bushing set up with the retainers all energy is selling is sleeves for a bot as a retainer. I was thinking of getting something like that from the hardware store. http://www.summitracing.com/parts/en...eJXTjNJifw_wcB
bdemutis is offline
post #9 of 14 Old 07-06-2014, 04:47 AM
Quoted: 4 Post(s)
That set is not for a Ford pickup, so they are different. Energy suspension has you reuse the steel retainers in their poly mounts. Our trucks take a #44107
You can reproduce the steel retainer, just make them the same as the original design
post #10 of 14 Old 07-06-2014, 04:56 AM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
That's my idea just get sleeves and a washer and tack it together.
bdemutis is offline
