Nicked my Auto Tran cooler line - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By richardi503
post #1 of 7 Old 07-02-2014, 05:49 PM Thread Starter
Long story short, I was putting in my DE down pipe and exhaust and nicked my tranny cooler line at the fitting with the sawzall. Damn cobra head down pipe!!!! Any way I now have a spewing leak. Line was to close to downpipe for comfort any way. I was thinking of put a 90 degree elbow and going down about two inches or more and then adapating back to steel tube. Any suggestions are welcome. Thanks
richardi503 is offline
post #2 of 7 Old 07-02-2014, 07:26 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Great time to update to the 3/8" SuperDuty lines maybe? Here are part numbers should you want to go that route:
Transmission Cooler Lines (SuperDuty 3/8”)
(Ford) Line F81Z-7A031CE
(Ford) Line F81Z-7A030CA
(Ford) By Pass Tube 2C3Z-7H322-BA
Hopefully the added fittings involved in a fix of the damaged lines won't add too much restriction. Cheers!
Patrick Feeley is offline
post #3 of 7 Old 07-03-2014, 01:40 AM
Chop's Avatar
Get you a 5/16 compression union to repair the line .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #4 of 7 Old 07-03-2014, 06:49 AM Thread Starter
I probably can use a union. Then I need to wrap them with some header tape to protect from the down pipe heat.
post #5 of 7 Old 07-03-2014, 07:27 AM
ZMANN's Avatar
Quoted: 1905 Post(s)
you probably know this but
if u need to drive it ? that line is the low psi side you could cut the hard line out and reroute with trans cooler hose for now untill you come up with a permanent solution
I would just dbl clamp since the hard line has no retention grooves
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #6 of 7 Old 07-03-2014, 07:09 PM Thread Starter
Smile
After trying a few unsuccessful solutions, ended up at the local tranny shop, $5 and had a new piece of swaged pipe and a compression fitting that was full flow. Now just to put it back together in the morning.
ZMANN likes this.
post #7 of 7 Old 07-05-2014, 03:35 PM Thread Starter
Mistake is now fixed. Worked quite well, let the motor warm up and retightened the compression fitting. No leaks added a 1/2 quart of ATF and ready to go. Thanks for the parts number for the SD lines. I am going to have to order them and install a larger cooler at the same time this winter.
