Track bar bracket question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-02-2014, 12:28 PM Thread Starter
lhsnbsaoa's Avatar
Garage
I tried searching and couldn't find my answer so I'll ask the question to everyone.
I have a 97 f350 bone stock and plan to do a leveling kit. On my previous f350's (2000 and 2008) I had to install a different upper track bar bracket to accommodate a leveling kit. However I cannot find a bracket for the OBS for just a 2-2.5 in leveling kit. Is the different bracket not necessary or am I just not looking hard enough.
Not looking to spend a ton of $$. Just leveling and putting on 305/70/16.
1996 F350 Dually Centurion
Previous trucks: 2003 F-250, 1997 F-350 CCLB, 2000 F-350 CCLB, 2008 F-250 CCLB
lhsnbsaoa is offline
post #2 of 4 Old 07-02-2014, 12:30 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Don't need one. You may need an adjustable track bar tho.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 4 Old 07-02-2014, 12:49 PM
erics diesel's Avatar
Pmf has drop brackets and adjustable track bars
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #4 of 4 Old 07-02-2014, 12:51 PM
Phillipjon's Avatar
Quoted: 78 Post(s)
www.sky-manufacturing.com - FordFullFab3InchPanHardDropBracket
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
