Irate Up-pipes Fitment Issue? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-01-2014, 07:27 AM Thread Starter
ja9788's Avatar
So I just picked these up a few weeks ago and got around to installing them this weekend. I had terrible fitment issues with the pedestal not lining up as well as the collector not sealing. Anyone else have any similar issues or am I flying solo here?
I did email Jake and got a 'we will look into it' response.
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #2 of 13 Old 07-01-2014, 01:26 PM
Quoted: 8 Post(s)
I had no issues with mine. I installed these on my truck and my brother in laws the same way with no issues. I did leave everything loose as I put it back together though. I put the pipes in then set the turbo in and just started the pedestal bolts. Then I started the bolts for the collector to the turbo housing with the gasket. Then went under the truck and lined up the manifolds and I snugged up those bolts. Not super tight but tight. Then I went back and tightened the pedestal then finally the collector bolts. Then I drove the truck a couple of heat and cool cycles and went back and tightened all the bolts again after everything settled in. After that no issues or leaks on either truck. I have been really happy with them.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #3 of 13 Old 07-01-2014, 05:48 PM
the baconator
terryknight's Avatar
Quoted: 144 Post(s)
i had an issue with the seal between the collector and the upipes. never got mine installed since they didn't seal.
wound up using different pipes
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 13 Old 07-01-2014, 09:19 PM Thread Starter
ja9788's Avatar
terryknight that was exactly the same issue I was having. I wish I had checked like you had before installing. I think I'm going to end up in the same boat as you and use something different.
Thanks for the replies guys
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #5 of 13 Old 07-01-2014, 10:29 PM
c69ss396's Avatar
That's why I bit the bullet and bought the international up-pipes I didn't want to have to fight with things. I hate having to do things twice or even worse get started on a job and find out something wont work and your stuck waiting for the right parts....
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 13 Old 07-02-2014, 04:32 AM
the baconator
Quoted: 144 Post(s)
it does suck. my truck was down for 3 weeks. luckily it was winter and i didn't need it
post #7 of 13 Old 07-02-2014, 12:18 PM Thread Starter
ja9788's Avatar
The International up-pipes would have been my first choice had they not been $800. I don't skimp for cheap parts at all but it was hard for me to justify spending that. Doing these once was enough for me. Twice is going to be a PITA.
Did you guys use an air hammer for the firewall or what was your method for creating space?
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #8 of 13 Old 07-02-2014, 12:26 PM
c69ss396's Avatar
I know what you mean, I hear the Riffraff sets are sweet for half the price. If they were made/bent correctly you shouldn't have to clearance anything. Mine went in easier then my old ones came out...
c69ss396 is offline
post #9 of 13 Old 07-02-2014, 02:36 PM
the baconator
Quoted: 144 Post(s)
remove trans = no issues
post #10 of 13 Old 07-02-2014, 03:49 PM
c69ss396's Avatar
I'd say your almost better off sending them back, Like Terry did, look into the Riffraff set maybe?
c69ss396 is offline
