Ambulance (engine replacement) - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-30-2014, 12:33 PM Thread Starter
With all of the miles and sitting idle on ambulance engines (7.3 diesel powerstroke), I'd like to know what members think about replacing an older engine with a refurbished one, on a E 350 or E450 chassis. What is the potential cost and pitfalls of purchasing and installation. Recommendations?
rlepperson is offline
post #2 of 4 Old 07-02-2014, 02:23 AM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
if its an ambulance engine you at least know it was kept up on maintenance
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #3 of 4 Old 07-02-2014, 08:32 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
But long idle times washes the walls down...
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 4 Old 07-02-2014, 02:41 PM
Quoted: 2 Post(s)
Why do you need to replace the motor?
Before you do anything about that, check compression. If it's got weak or uneven compression, then go for it, but if it's got solid compression on all 8, then there's no reason to worry about the engine - just fix the stuff that needs fixing and go.
Syonyk is offline
