Recalibrate Speedomter - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-29-2014, 02:11 PM Thread Starter
I put new tires on. They are a little smaller than what was on my truck originally. How can I recalibrate the speedometer?
Thank in advance!
mikeallenbrown is offline
post #2 of 10 Old 06-29-2014, 02:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are they smaller then stock?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 10 Old 06-29-2014, 03:01 PM Thread Starter
Yes ... when I bought the truck they had 285's on it. Now I have 265's.
post #4 of 10 Old 06-29-2014, 03:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Was it calibrated to run the 285's? Kause isn't 235 stock?
Here ya go
speedometer calibration - PowerStrokeNation : Ford Powerstroke Diesel Forum
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 10 Old 06-29-2014, 03:36 PM Thread Starter
Talking
Here ya go
Thanks! ...I'll check out your link.
I have no idea what stock tires were when the truck was made 17 years ago. All I know is that the truck had 285's and the speedometer was accurate when compared to my GPS.
post #6 of 10 Old 06-29-2014, 09:02 PM
Quoted: 50 Post(s)
Are the two sets of tires the same profile?
madpogue is offline
post #7 of 10 Old 06-30-2014, 06:48 AM Thread Starter
Yes...all four tires are the same.
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
post #8 of 10 Old 06-30-2014, 07:29 AM
Quoted: 50 Post(s)
Are the two SETS of tires the same profile?
(Hint: two sets = EIGHT tires....)
madpogue is offline
post #9 of 10 Old 06-30-2014, 07:56 AM
Phillipjon's Avatar
Quoted: 77 Post(s)
Here are the diff.
Tire Dimensions Made Simple - Discount Tire
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #10 of 10 Old 06-30-2014, 07:57 AM
Phillipjon's Avatar
Quoted: 77 Post(s)
It is so close it is not even worth the work.
