New to diesels. What to do? - Ford Powerstroke Diesel Forum
post #1 of 25 Old 06-26-2014, 06:18 PM Thread Starter
I've had everything from low riders to lifted trucks to 400hp awd ricers. I've always been a ford guy though. Been wanting a 7.3 for awhile and I'm about to buy one. The truck I'm looking at is a 96 f250 excab long bed 2wd 5speed. I've know the owner for awhile. He's the second owner. It is all stock accept for a k&n filter in stock intake. It has 273k on it seems to run very well no leaks or smoke. I forgot to check for blow by but will if I go to buy it. $3800 is his bottoms dollar and I feel like that's a good deal. Is there anything else to look for? Everything works. Good tires straight body. I will be using it for a daily driver and occasionally hauling my Suzuki Samurai. I don't really want to make it a race truck but I want it to run and pull good. I figured I would go with a s&b intake with a 3" dp to 4" straight. What kind of tuner should I get? Anything else I should do? Thanks in advance.
TeXaS SoB is offline
post #2 of 25 Old 06-26-2014, 06:53 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Sounds like you have covered the big things already to watch out for and upgrade. As for tuners get a custom tuned chip from php, TS with someones tunes such as tony Wildman. Do not go with a edge. I know from experience the edge is super smoky and actually feels like there is less power than stock. 3800 bucks is a great deal in my opinion. I paid 4k in 2010 for my 94.5 with 267k and rusted rear fender wells lower rear of front fenders and cab corners are starting to rust.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 25 Old 06-26-2014, 06:58 PM
Phillipjon's Avatar
Quoted: 78 Post(s)
Take a look at the turbo wheel. K and n filters are know to dust turbos.
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #4 of 25 Old 06-26-2014, 07:00 PM
Finally7.3's Avatar
IMO a 6637 intake is the way to go. Cheaper, easier to install and maintain, and flows plenty.
I ran tony wildman tunes on my '95 and they worked great.
If you're keeping the stock fuel system an FPR shim is always a great way to flow some extra fuel on the cheap.
But the downpipe is a biggie too, stock pancake pipe is extremely restrictive. Have fun installing yours I know i did
Getting air and fuel in and exhaust out, and good tunes will make for a fun and reliable truck.
BTW, congrats (in advance) on your first 7.3. Hopefully you love it as much as I did my first haha.
97 F-350 ZF-5 CCLB 4x4 D60/10.25 3.55s. 216,000. 6637,FPR shim, 3" DP to 4" exhaust, leveled, ION Alloy 171's, 315/75/16 Kelly Safari TSR's, some cosmetic goodies.
NEEDS: Rosewood 160/30's, beans tunes, T500, Autometer gauges, lockers, some chassis parts, a few other things
Someday I'll do a full build on it.
Gone but never forgotten-1995 F-250 7.3 PSD 5 Speed 4x4 SC LB. Man-o-day did that truck get up and go.
"Smoke? Whistle? Stroke."
Finally7.3 is offline
post #5 of 25 Old 06-26-2014, 07:21 PM Thread Starter
Yeah I've read that about k&n's on turbos. It will be coming off. Also how does a for ( I assume fuel pressure regulator) shim work? I've read a lot about the TS chip as well. Ppl seem to like it a lot. I've also read about the 6637 mod may go that route instead and save some money. Just seems like the s&b would be better.
post #6 of 25 Old 06-26-2014, 07:27 PM
Finally7.3's Avatar
there is a brass plug on the side of the fuel pressure regulator ( I believe it was 19mm IIRC) You remove that plug and pull out the spring inside and shim it out. Some people use the heads of screws I used a copper BB and it worked perfectly. cleans up the idle and gives you a little better fuel pressure.
there are quite a few threads on here that give pics and more detailed explanations of it. but its only about a 10 minute job and worth the time just to stop some of the shake when you're sitting still if nothing else
post #7 of 25 Old 06-27-2014, 05:40 AM
dr.deere's Avatar
Quoted: 19 Post(s)
If a k&n is properly maintained and oiled it won't hurt anything. I personally have been using them for years and know of dozens of trucks from ford dodge Chevy that have been using them with no issues. My 94 has had a k&n in the stock filter housing for 120k and 10k on an intake setup. Turbo is still in good shape. Currently with 280k on the clock. I've known my 94 since it had 140k. Turbo has never been touched.
Sent from AutoGuide.com App
dr.deere is offline
post #8 of 25 Old 06-27-2014, 06:47 AM Thread Starter
Yeah I've ran k&n's on multiple gas vehicles with no problems. Even on my turbo eclipses. Will a exhaust shop run a straight exhaust with no car or muffler or should I buy one aftermarket?
post #9 of 25 Old 06-27-2014, 01:55 PM
Finally7.3's Avatar
I don't know what its like where you are, but around here no exhaust shop is able to do 3" or bigger exhaust. I've run diamond eye kits (no muffler no cat) on all my 7.3's and got them all off of ebay. they're pretty cheap on there, and you can buy them in multiple configurations (cat/no cat, muffler/no muffler, with or without DP, 4",5", duals) Also, every time i bought the kits from the shops on ebay, they threw in free tips for it. And they were actually nice, rolled edge tips and the chrome didn't flake off or get dull.
just my 2 cents
post #10 of 25 Old 06-27-2014, 03:09 PM Thread Starter
Yeah I've looked at those. And a few other seems like decent prices. I'm gonna ask my local shop first cause I know they've done them and go from there. Looks like I should go 3" dp but what about the rest 4" or 5"?
