I've had it with my wipers... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-26-2014, 01:21 PM Thread Starter
Pwnm30rdi3's Avatar
My wipers are still giving me trouble.
They only have 2 speeds. Intermittent and Fast. They also refuse to return to the park position.
I've replaced the following:
Brand new Windshield Wiper Motor
Brand new Multifunction Switch
Brand new Wiper Relay Box (behind glove box)
What is causing this? I've dumped like $275 trying to get these windshield wipers working properly. I'm in need of some help...
Thanks guys,
Andrew
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 8 Old 06-26-2014, 01:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are they sticking to the windshield when you turn them off? Like you can lift and they go down the rest of the way?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 06-26-2014, 02:07 PM Thread Starter
Pwnm30rdi3's Avatar
It seems like they just stop in their tracks.
I've taken both wiper arm's off and it does the same thing regardless of if the wiper arms are installed.
If I spray washer fluid, the wipers get stuck on and only turn off when I turn the truck off... Grr.
Could the GEM have anything to do with this?
1997 F350
post #4 of 8 Old 06-26-2014, 02:36 PM
Quoted: 59 Post(s)
There is no GEM. I'd have to check the EVTM, but speculating, I'd say it's the always-on power to the wiper circuit through the MF switch that's the problem. Wiper circuits always need one wire that's always hot (well, "always" meaning when the key is "on"), in order to run the motor to the PARK position when you turn them off.
madpogue is online now
post #5 of 8 Old 06-26-2014, 05:58 PM Thread Starter
Pwnm30rdi3's Avatar
Any easy way to test this?
I bought my MF switch through LMC, I've heard horror stories about quality control issues with LMC products!
1997 F350
post #6 of 8 Old 06-26-2014, 09:49 PM
Quoted: 59 Post(s)
http://userpages.chorus.net/elephant/Wipers.pdf - too big to attach. Note sections on "LO Speed inop" and "Wipers will not park".
I would also test the functions of the various pairs of terminals on the MF switch, both the old one and the new one.
post #7 of 8 Old 06-26-2014, 10:34 PM
Quoted: 9 Post(s)
What manual is that from? That looks like the coolest manual ever. The detail is Awesome!
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #8 of 8 Old 06-26-2014, 10:47 PM
Quoted: 59 Post(s)
Factory EVTM.
