Question about tire size - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-25-2014, 03:15 PM Thread Starter
Finally7.3's Avatar
Question Question about tire size
Hey all,
It's been quite a while since I posted. Took me a long time to find the truck I really wanted. Now I'm back to the days of burning every dime on a truck
I ordered a set of Mickey Thompson Classic IIIs in 16x12 and I'm getting ready to order a 4" lift from rough country because the front springs are shot anyway. My question is, how tall of a tire can I run with that lift? Truck specifics are in my signature. Can I go an inch or two taller with bumper shims? And if the shims will help, how far should I shim it?
The kit recommends a 35x12.50 tire, but I know that I've seen people run those on an OBS F350 with just stock suspension, so I'm figuring I can go bigger.
97 F-350 ZF-5 CCLB 4x4 D60/10.25 3.55s. 216,000. 6637,FPR shim, 3" DP to 4" exhaust, leveled, ION Alloy 171's, 315/75/16 Kelly Safari TSR's, some cosmetic goodies.
NEEDS: Rosewood 160/30's, beans tunes, T500, Autometer gauges, lockers, some chassis parts, a few other things
Someday I'll do a full build on it.
Gone but never forgotten-1995 F-250 7.3 PSD 5 Speed 4x4 SC LB. Man-o-day did that truck get up and go.
"Smoke? Whistle? Stroke."
Finally7.3 is offline
post #2 of 12 Old 06-25-2014, 03:19 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A 35 is recommended I. The event of articulation where you will catch the bumper/fender/bed side
That being said I've seen 37's bumper shimmed maybe 1/2-1" but I would say go RSK over rough country
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 06-25-2014, 03:24 PM Thread Starter
Finally7.3's Avatar
What all is needed for RSK? I've never actually seen a truck with that done. Be detailed if you can, I don't know much about it. And I'm assuming you run it with just blocks in the rear?
post #4 of 12 Old 06-25-2014, 03:27 PM Thread Starter
Finally7.3's Avatar
I'm more or less comparing the price of the kit with everything involved to do RSK, if that clarifies what I'm looking for.
post #5 of 12 Old 06-25-2014, 05:08 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Do a search on here. RSKs have been done a TON. they not only give you lift, but also give a much better ride. SuperDuty springs w the RSK give even a better ride
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #6 of 12 Old 06-26-2014, 07:51 PM Thread Starter
Finally7.3's Avatar
on a completely separate note, if i decide to hold off on the lift for a little while, what would need to be done to squeeze 315/75/16's under the truck?
post #7 of 12 Old 06-26-2014, 09:20 PM
Phillipjon's Avatar
Quoted: 76 Post(s)
Your F350 has a Dana 44?
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #8 of 12 Old 06-26-2014, 09:34 PM Thread Starter
Finally7.3's Avatar
whoops. I just updated my signature last night. Im glad someone caught that because I wouldnt have. Its a Dana 60, and I'm going to fix that now lol thanks
post #9 of 12 Old 06-27-2014, 02:51 AM
Quoted: 4 Post(s)
A cut and shimmed bumper
post #10 of 12 Old 06-27-2014, 02:43 PM Thread Starter
Finally7.3's Avatar
about how big of a shim?
Tags
lift , obs , tire clearance
