1997 F-250 Solid Axle Swap Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-23-2014, 09:51 PM Thread Starter
Hi guys,
I know this has been discussed many of times but I can never find a solid answer for what information I'm looking for. I know if you get a donor truck this should be a drop in swap. I'm confused about what years you can get away with a simple bolt in job. I've read 1987-1997 f350's are a direct bolt in but I found a perfect donor truck and it's 1986. I'm not completely sure but isn't this on the same platform as the 'newer' trucks? I guess what I really want to know is if I got this 1986 F350 4x4 I would have all the parts I need to convert my 1997 twin I beam set-up to a solid axle configuration. That would include not only the axle but the steering and what not. Help would be appreciated! Sorry for bringing up an old topic! I just need clarity! Thanks
BasedJake is offline
post #2 of 3 Old 06-24-2014, 12:05 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I always thought it was 85 to 97 that were direct swaps.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 3 Old 06-24-2014, 05:04 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The correct answer is 1986-1997 f350 is almost a direct swap, the 86-94/95 have slide pin calipers so the brake line has to be "fabbed" to fit, all that is going to be is grinding off the tab that sticks off the bottom of it, the 95/96-97 models have bolt on calipers
1980-1985 used a d50 front axle, so stick with 86-97 you will have a complete direct bolt in axle, also keep in mind the power plant above those springs, the gasser engines are considerably lighter so the springs are softer
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
