Coolant type and mixing question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-22-2014, 01:37 PM Thread Starter
My truck needs some coolant. It's definitely not the green stuff. It looks yellow or orange. Is it safe to assume that dexcool orange coolant is safe to top off with? ....I don't know what coolant is in it now. I bought the truck only a few weeks ago.
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 11 Old 06-22-2014, 01:46 PM
Tennessee Powerstrokes
GoFastPadre's Avatar
My suggestion would be since you don't know don't guess. I would get distilled water to top it off with and then get or order a Nitrite Free ELC that is Cat approved, 3 gallons full strength. It would be a good idea to flush the system with Restore Plus and then refill with the new coolant and distilled water. You will need to remove the drain plugs from the block to properly drain the system too.
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
post #3 of 11 Old 06-22-2014, 09:34 PM
Quoted: 54 Post(s)
Do NOT use Dex-Cool! It was very specifically formulated for use in GM engines, and even with that, it was problematic.
Do not use ELC; our trucks are not compatible with ELC. Unless what you're seeing is more pinkish-orange than yellowish-orange, the PO probably used one of the yellow-dyed ELC products, which means you should def. change the coolant. If it looks more pinkish, there's a possibility that it's FleetCharge, which is old-school ethylene glycol with SCA added. You should use either FleetCharge, or plain-old green anti-freeze and SCA.
Three gallons is not enough; you need FOUR gallons of anti-freeze and the rest distilled water. You'll need to remove both block drains AND open the radiator drain. You should also flush the system via the heater hose with a tee. Drain again, fill with distilled water, drain once again (to flush out the tap water from the garden hose), then add distilled water and anti-freeze (and SCA if applicable). One of the diesel forums has a more detailed procedure, written by a guy who goes by Gooch. Just do a general search on "gooch coolant flush" or something; you'll find it.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
mikeallenbrown (06-23-2014)
post #4 of 11 Old 06-23-2014, 06:16 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
^2nd, this is OBS gospel right here^
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 11 Old 06-23-2014, 06:19 AM Thread Starter
Great...thanks!
I'll be picking up some fleetcharge here soon. I'm in the process of getting new hoses and a 203 degree thermostat. Also picked up a coolant filter.
Mike
post #6 of 11 Old 06-23-2014, 06:24 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
There has been a rash of people on here changing out the thermostat and not getting all the air out behind it first. ALWAYS drill a tiny (like 1/64" tiny) hole in the rim of the thermostat and you wont have an issue.
This one comes from the factory like this but same effect. This tiny hole will allow the trapped air to get past the thermostat and keep the overheating blues at bay:
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
The Following 2 Users Say Thank You to BigFuel For This Useful Post:
madpogue (06-23-2014), mikeallenbrown (06-23-2014)
post #7 of 11 Old 06-23-2014, 07:05 AM Thread Starter
Thanks for the tip!
Mike
post #8 of 11 Old 06-23-2014, 08:08 AM
Quoted: 54 Post(s)
Are you near an Advance Auto? Deal option - find out if the AA near you carries the FleetCharge, order it online for store pickup, then hit TRT30 in the promo code, 30% discount, brings it down to aprx. $11 /gallon.
madpogue is offline
post #9 of 11 Old 06-23-2014, 02:54 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I second the regular old Green anti freeze with the SCA additive(napa kool)
You can get it EVERYWHERE, unlike some of the other specialized coolant
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 11 Old 06-23-2014, 03:01 PM
Quoted: 54 Post(s)
Green anti-freeze may be available everywhere, but the SCA is available in fewer places than Fleet Charge. You can get Fleet Charge at Tractor Supply these days. Only places I know of for SCA are the International dealer (muy expensivo), online or NAPA. All depends on what's in your neighborhood.
madpogue is offline
