Fuel Line Part Number - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-21-2014, 03:05 PM Thread Starter
Quoted: 9 Post(s)
I blew a fuel line today. Man what a mess. It was the high pressure line that goes from the FPR to the passenger head. It is not the fittings the rubber line split on me. I was towing my trailer at the time and it pretty well misted down the whole engine bay and leaked all over the place. WHAT A MESS. Thank GOD it didn't light off on my turbo and burn my rig down. So now I need to find a place to buy these lines. Any ideas on a part number or a good vendor? I am thinking about running them down to me local Whistler Bearing shop and having a set of braided steel lines to be custom made.
I found this one on Riff Raff but they only list a passenger line is the driver the same?
Passenger Side Fuel Line 94-97 - Riffraff Diesel Performance
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #2 of 6 Old 06-22-2014, 10:31 AM
elrojo63's Avatar
Rubber line can be purchased at napa or a heavy truck shop. There's nothing special about it. Is one pita to clean up the motor when one of them blows.
Sent from AutoGuide.com App
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #3 of 6 Old 06-22-2014, 11:13 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
i had some made up at the local truck shop. with the fittings they were $25ish a piece. i got reusable fittings.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 6 Old 06-22-2014, 11:17 AM
66Bronco's Avatar
Go ahead and replace both of them. Trust me. Also, the driver side hose is a PITA because you've got to pretty much disassemble the accessory bracket on that side to get to the fitting on the head.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #5 of 6 Old 06-23-2014, 05:41 PM
When I click your link it has the drivers side listed on the bottom of the page.
Here it is,it's a diff. part #
Driver Side Fuel Line 94-97 - Riffraff Diesel Performance
Superjunk is offline
post #6 of 6 Old 06-23-2014, 06:37 PM Thread Starter
Quoted: 9 Post(s)
Thanks. Not sure why I didn't see it before but I called RiffRaff and they hooked me up. My lines are on their way. Good thing too the rigged repair just barely got me home. i had some hose that just happened to be the right size to slip over the leaking line and I clamped it on the metal shoulders of the fittings. It stopped the leak but the other hose was neither fuel rated or pressure so it swelled up and got all puffy but it didn't leak for the 50 miles I had to drive to get her home. But I won't be driving it until I get the new lines installed.
