IDI radiator in OBS - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-21-2014, 02:45 PM Thread Starter
JSchuricht's Avatar
IDI radiator in OBS
So I just learned something new. The waterpump in my 95 is leaking so I bought an International pump/filter, lower hose and the Dieselsite billet thermostat housing and upper hose. For once I was smart enough to mock up the hoses before ripping everything apart and discovered that not all OBS radiators are the same. Both the upper and lower ports are on opposite sides from most other trucks. A little Googling and it turns out that 94 and apparently 95 trucks built in 94 have a IDI radiator.
My options now are
1) Send the upper hose back to Dieselsite and use flexible hose for both upper and lower.
2) Convert to a 96/97 coolant system. Initial research shows radiator, fan shroud and degauss bottle.
The big question for anyone that has done it (havn't found any threads on it yet) is is there any advantage to the 96/97 system over the IDI one?
How it is.
How it should be.
How it is.
How it should be.
JSchuricht is offline
post #2 of 20 Old 06-21-2014, 03:15 PM
erics diesel's Avatar
Yes the 94 and first part of 95 (until they used all of the ones they had) are the same as the Idi. Personally I like the earlier ones with a radiator cap.
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 20 Old 06-21-2014, 03:22 PM
It might be a good time to switch to this Mishimoto OBS Radiator Sale $289! - PowerStrokeArmy
Rusty
rusty1161 is offline
post #4 of 20 Old 06-21-2014, 03:58 PM Thread Starter
JSchuricht's Avatar
Rusty
Tempting... Need to see if I can find the fan shroud and degauss bottle plus anything else needed for the conversion.
post #5 of 20 Old 06-21-2014, 04:35 PM
c69ss396's Avatar
Go ahead and get the 6.0 fan too! Your truck will thank you....
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 20 Old 06-21-2014, 08:15 PM Thread Starter
JSchuricht's Avatar
The plastic fan is on my list but I am still not convinced converting the cooling system to 95 1/2+ is worth it even with the killer price on an aluminum radiator. I think the existing radiator is CU and it's 20 years old so preventative maintenance is the only good reason I can find to replace it.
I haven't found a comprehensive list of parts needed but...
AL Radiator $340 shipped
Degauss bottle $100 shipped
Fan shroud $50 shipped (need to find out if gas/diesel are the same)
or
Return upper hose -$80
Shiny flexible upper hose $80
Bottom hose with opposing 90 bends and coupler $??
post #7 of 20 Old 06-22-2014, 08:56 PM Thread Starter
JSchuricht's Avatar
Ok, bit the bullet and ordered the Mishimoto radiator and degauss bottle. I still can't find any info on the fan shroud other than a few posts saying it's different between the 94 and 95. I think I will try and make my existing one work, the fan position doesn't change and the radiator uses the same brackets so I guess I will find out soon if it will work.
post #8 of 20 Old 07-26-2014, 09:50 PM
c69ss396's Avatar
Hows your swap coming along?
c69ss396 is offline
post #9 of 20 Old 07-26-2014, 11:49 PM Thread Starter
JSchuricht's Avatar
Slow, the aluminum radiator is on back order till September 1st despite their website still showing in stock.
post #10 of 20 Old 07-27-2014, 01:11 AM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
the 96+ water pump uses longer bolts than the 94.5-95.5. there are 9 bolts, 6 short and three longer. you can reuse the short ones but need new longer ones. i think the earlier ones are 100mm and the later ones 110m
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
