7.3 No Start! - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-18-2014, 03:06 PM Thread Starter
7.3 No Start!
Hi guys im new here but not new to fords I have plenty of gas fords even a drag one I will show u guys one day but I wanna buy a diesel and I found this 1996 forsale that wont start.. the guy is a diesel technition even he cant start it here is whats been done by him.. harnass open and fixed all bad wires.. full fuel system fix even a new fuel bowl.. new IDR..new ipr valve.. remove o hpop pump and change o rings(sounds fishy) and changed the plugs on the valve cover with gasket.. and cheked cpr and stuff.. but the icp plug has oil on the connection.. and here is what I tried with it.. I put the ids on it and cheked icp pressure when crank it was zero even the disired was zero and when I unplugged it then the disired show the desired pressure.but the reading of icp was 0 I dunno if maybe the batteries where weak?. and codes (this is disturbing) bank 1 and 2 high side open. Then I cheked the pcm I put it on another truck it started right up.. I dont know what else to chek? He wants to trade me for an old f150 I have with an mustang engine I have for the truck.. it seams fair the prices are the similair range but I dont wanna get it and put have to tons of money in this thing.to get it running. what should I do? Where to start??? Its a 1996 f250 auto 4x4
F150Cobra is offline
post #2 of 20 Old 06-18-2014, 05:07 PM
PSDTV21's Avatar
Any smoke while cranking?
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 20 Old 06-18-2014, 05:08 PM Thread Starter
Nothing not a puff not a hick nothing dead dead
post #4 of 20 Old 06-18-2014, 05:11 PM
PSDTV21's Avatar
Ok then. Try putting some oil in the hpop resivior. Fill it to the top and try starting it again
-Tyler
1994.5
PSDTV21 is offline
post #5 of 20 Old 06-18-2014, 09:10 PM Thread Starter
It is full my friend
post #6 of 20 Old 06-19-2014, 04:00 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Does the wait to start light come on? Did you swap idm's?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
bertieb (02-28-2015)
post #7 of 20 Old 06-19-2014, 08:09 AM Thread Starter
Yes and yes my friend..
post #8 of 20 Old 06-19-2014, 09:00 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
You need to get a scanner that can do a buzz test. Did he just replace the uvch's and the pig tails. If he used butt connectors on the pig tails it could not get a good signal and and it won't fire. What does harness open and wires fixed mean? 0 psi on icp when unplugged? Check the pig tail for the icp. Also check ipr pig tail.
01 f-250, Standard
sbluke55 is offline
post #9 of 20 Old 06-19-2014, 09:07 AM Thread Starter
I did do a buzz test it passed.wr heard all 8 injector buzz And it show codes for bank 1 and 2 high side open.. lenme chek on those connectors what he did and I will get back to you.. thanks!
post #10 of 20 Old 06-19-2014, 09:08 AM Thread Starter
I have acces to a ford IDS btw for scanning and tests
