Will not start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-16-2014, 02:55 AM Thread Starter
Will not start
So, I am having problems getting my truck to start. I could do with some advice before I start to throw cash at it.
Here's a summary of what happened. Also I drive it daily.
I started it to go to work and it seemed to misfire slightly at idle, i mean barely noticeable but only happened when I was turning when reversing out of my driveway.
I drove 15 miles to work and she drove perfect.
Idled at work and zero misfires.
Went to the store a couple of mile from my work a few hours later. I parked, turned her off then noticed a better space so I started her back up and moved her.
Bought my groceries then when I got back to the truck it would not start, turned over really lazy like the batteries were low.
I had a friend try to jump start me with a Subaru forester, it wouldnt start but still didnt seem to crank fast enough. I did find a battery terminal loose.
I called roadside recovery and And they had a Ford Fusion :/ and a booster thing. they connected both up and it turned over fast and would sound like it was going to start but it never did start, although it was probably slower than normal. The RPM's at cranking were 500/600.
Any ideas? Would a bad battery prevent it from starting?
I did check for fuel in the bowl and it seems fine.
97 super cab 4x4
165k
4" turbo back diamond eye exhaust
DIY intake
IRNBRU is offline
post #2 of 8 Old 06-16-2014, 03:53 AM
I doubt it cranks 500-600 rpm unless you have a nippendenso starter. The magic number you are looking for is at least 125rpm cranking.
Wouldn't hurt to check the oil level also.
Does your wait to start light illuminate?
Power-Struck dot com
POWER-STRUCK is offline
The Following User Says Thank You to POWER-STRUCK For This Useful Post:
IRNBRU (06-16-2014)
post #3 of 8 Old 06-16-2014, 04:34 AM Thread Starter
The WTS light comes on and off as normal. My batteries are 3 years old and I do a lot of short journeys. One thing I did notice when trying to jump start it is that it seemed to be better when the cables were hooked up to the passanger side as opposed to the driver side. It never slow cranked before this no start issue appeared.
I was convinced it was the batteries but i have been unable to jump start it although I have only tried to be jumped from cars. the 600 or so RPM was during the firing but no start stage.
I want to buy new batteries but I fear that I may just be hoping that thats my problem.
97 super cab 4x4
165k
DIY intake
IRNBRU is offline
post #4 of 8 Old 06-16-2014, 04:44 AM
Place a battery charger (ground on engine/ positive on the starter relay hot terminal) then test voltage on each battery directly from the center of each battery post. Watch for inconsistent voltage between the batteries. The cables can fail or come loose at the ground bolts on the block causing one battery to become inoperable.
If it is cranking at least 125rpm I would suspect something else as the culprit for the no start condition
IRNBRU (06-16-2014)
post #5 of 8 Old 06-16-2014, 04:54 AM Thread Starter
The oil level is good. I also cleaned the FPR screen 6 months ago when I last did my fuel filter and oil change. I am going to test the batteries with a DMM to see if there is a voltage difference between the 2.
I just cannot get past the fact that the batteries were nearly dead the first time I cranked it.
thanks for your help!
97 super cab 4x4
165k
DIY intake
IRNBRU is offline
post #6 of 8 Old 06-16-2014, 07:24 PM Thread Starter
SO....I would like to follow up on the resolution
Turned out to be a binding alternator pulley. I replaced the batteries as one measured only 600 cranking amps. The new batteries are 1000cca.
Cranked it and it started very lumpy and the belt started smoking as the pulley was seized. Replaced the alternator and belt. All is good
97 super cab 4x4
165k
DIY intake
IRNBRU is offline
post #7 of 8 Old 06-16-2014, 07:55 PM
Quoted: 2 Post(s)
That would do it. Glad you got it fixed! I'm hoping my current batteries make it through the summer - planning to swap them before winter hits again.
Syonyk is offline
post #8 of 8 Old 06-16-2014, 10:49 PM Thread Starter
The strange thing is that the pulley did not make a noise. No warning at all, although its not easy to hear much over the engine.
Now I have 2 reasonable batteries that I plan to hook up to an 120vac invertor for camping.
IRNBRU is offline
