At The JY Question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-14-2014, 10:56 AM Thread Starter
Quoted: 9 Post(s)
At The JY Question
Will the hubs on a 90 2wd dually truck be able to be put on the Dana 60 front to convert it to a dually? I found a set in the local pull and pay and I could use them.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #2 of 2 Old 06-14-2014, 11:22 AM Thread Starter
Quoted: 9 Post(s)
Also, on the rear. Can you just pull the hubs off from the dually axle and swap them on to the SRW axle to convert it to a dually?
