Oil cooler problem; Please Help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-14-2014, 08:23 AM Thread Starter
I just changed my oil cooler/adaptor because springs fell out of the old one. I got it all together, put the fluids back in, started the truck and in my radiator it looked like chocolate milk. I think the first thing is I am screwed, but would like to know what is going on. I am almost positive that I put everything together correctly. All help is appreciated!
1995 Powerstroke F-250
Super Cab 4x4
2012 F-250 CC Lariat 6.7 4x4
grish is offline
post #2 of 6 Old 06-14-2014, 04:48 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Check the o-rings on the cooler tube or make sure the adapter gaskets did not get damaged.
dirtcrew51m is offline
post #3 of 6 Old 06-15-2014, 11:00 AM Thread Starter
I am about to get it off again and check everything. Is there a wrong direction the oil cooler can go in? And what is the best way to make sure I have all the antifreeze out if the oil pan?
grish is offline
post #4 of 6 Old 06-15-2014, 11:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Drain it twice
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 06-16-2014, 05:34 PM
rolsmojave3's Avatar
You can use water and dawn dish soap to clean the cooling system of oil.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #6 of 6 Old 06-17-2014, 12:43 PM
TRUKK30's Avatar
It is very easy to damage the O-rings when putting the cooler together. Make sure there are no burrs on the inside were they seat. Lubricate the o-rings good before assembly. I have rebuilt two in the past month and on one I had to use a press to gently get the ends on the cooler.
TRUKK30 is offline
