Latest and Greatest - Ford Powerstroke Diesel Forum
post #1 of 31 Old 06-13-2014, 07:06 PM Thread Starter
Latest and Greatest
alright guys i just picked up 95 regular cab with 59,000 original miles with a Firm ZF-5. It was a Kentucky State Plow truck. What ever they friggin use in that state for road treatments in the winter, is some potent stuff. The frames rotted and has a huge patch job on it, and the cabs so rotted its about to fall off. I have a 96 f250HD gasjob,automatic that im gonna take out and replace with the 7.3 and the ZF-5. So my question is really about installing the manual components into a truck that has auto wiring and the clutch.i know im goin to switch the instrument panel out too. Has anyone ever done this before or am i just crazy? Thanks
[SIGPIC][/SIGPIC]Late 95 F250 XLT Ext. Cab Long Bed
4in Rough Country on 34s
Built E4OD w/ Triple disc TC
Swamps Stage 1 w/ Swamps ts-6
IRATE E-Fuel w/fuel lab regulated return
Swamps IDM
Adrenaline HPOP
Melling LPOP
4in pipe all the way back w/ 7in matte black tip
AFE intake with Napas "Big Dog" air filter
Banks Fast Spool comp housing
EBPV gutted
Wicked Wheel 2
GLOW SHIFT 4 gauge pillar
MM lock out hubs
limo tints all the way around
RushFORD is offline
post #2 of 31 Old 06-13-2014, 10:53 PM
chaneye1's Avatar
Quoted: 24 Post(s)
I know some guys on here have done the zf5 swap, I remember reading a form about what all is involved, lucky for u u have a donor truck and not trying to piece it together! Good luck! Def post some pics when ya get it done!
1997 7.3 powerstroke, mbrp 4 inch turbo back, ts 6 pos chip, 6637 air filter
chaneye1 is offline
post #3 of 31 Old 06-14-2014, 05:34 AM Thread Starter
Alright cool, and as for the diesel swap ill need a new radiator, but im not sure about the housing, to put in it i was gonna remove the front clip and just plop the motor and trans in at the same time, is this possible?Will i need to get new motor and tranny mounts?
Swamps IDM
Adrenaline HPOP
Melling LPOP
EBPV gutted
Wicked Wheel 2
MM lock out hubs
RushFORD is offline
post #4 of 31 Old 06-14-2014, 07:08 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
You will need the diesel core support to go with the radiator, along with
Trans cross member
Rear driveshaft if same body style
ALL engine wiring and Trans wiring
Steering column or all pieces needed
Instrument panel and dash bezel with diesel WAIT TO START cluster
Possibly engine cross member depending on what engine you had or drill new holes for engine mounts
Exhaust
Not sure on fuel lines and selector valve
I'm sure I'm forgetting something
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 31 Old 06-14-2014, 06:10 PM Thread Starter
OL'Blue, your the man, would i need to change the driveshaft if the both regular cab?
im gonna see if i could get some pics on here of the 2 trucks.
Swamps IDM
Adrenaline HPOP
Melling LPOP
EBPV gutted
Wicked Wheel 2
MM lock out hubs
RushFORD is offline
post #6 of 31 Old 06-14-2014, 06:24 PM Thread Starter
https://mail.google.com/mail/u/0/?ui...1&disp=safe&zw
Swamps IDM
Adrenaline HPOP
Melling LPOP
EBPV gutted
Wicked Wheel 2
MM lock out hubs
RushFORD is offline
post #7 of 31 Old 06-14-2014, 06:36 PM Thread Starter
[IMG]file:///C:/Users/kevin_000/Pictures/IMG_20140613_145312%20(1).jpeg[/IMG]
Swamps IDM
Adrenaline HPOP
Melling LPOP
EBPV gutted
Wicked Wheel 2
MM lock out hubs
RushFORD is offline
post #8 of 31 Old 06-14-2014, 08:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Yes the front will need to be swapped as well
Pik fail
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 31 Old 06-14-2014, 09:01 PM Thread Starter
What's the best way to post a pic....and do u mean the front driveshaft?
Swamps IDM
Adrenaline HPOP
Melling LPOP
EBPV gutted
Wicked Wheel 2
MM lock out hubs
RushFORD is offline
post #10 of 31 Old 06-14-2014, 09:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If your going from auto to stick the front shaft is a different length, and do you have photobucket
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
