OBS to Superduty caliper upgrade? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 06-13-2014, 02:46 PM Thread Starter
seven3stroker's Avatar
Hey y'all,
So had my right front caliper lock up and eat a pad and tear up the rotor. So in my looking to upgrade while replacing, I noticed we don't really have any upgrades to do. So this got me wondering why superduties have option like SSBC and we don't since we all use a D60. Went down to the parts store and had them pull a 97 caliper and a 99. A quick side by side comparison shows the mounting brackets look the same. Not sure if bolt size and thread are the same though, would need to go back and check again? If I recall our rotor sizes aren't that different either? So other than that the SD use a slide pin type caliper what is stopping me from bolting on a upgraded SD caliper? Any insight y'all have would be great!
Sent from AutoGuide.com App
1997 F-350 PSD CCLB 4x4 215k ZF-5
SGT Roth, US Army
seven3stroker is offline
post #2 of 28 Old 06-13-2014, 02:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's an 8x170 bolt pattern, so your gonna buy new wheels too?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 28 Old 06-13-2014, 03:03 PM Thread Starter
No, keep my obs 8x6.5 rotor. The carquest computer says there 8thousands of an inch diffence in rotor diameter. Asking if I can bolt a SD caliper over a OBS rotor.
SGT Roth, US Army
post #4 of 28 Old 06-13-2014, 04:38 PM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
try it and let us know how it works. i think you can also buy blank rotors and get them drilled
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 28 Old 06-14-2014, 05:21 PM Thread Starter
I'll pick up a caliper and see if it fits. And I'll post back up, went and grabbed a set of SD pads today and the seem to have the exact same arch. Only difference I saw was that the pad material was shorter and a little thinner than OBS but that could just be autozone cheapies.
SGT Roth, US Army
post #6 of 28 Old 06-14-2014, 08:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I just picked up an 01 today I'm doing bearings on tomorrow I may try and see the difference while I'm at it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 28 Old 06-15-2014, 12:20 AM
hijo202's Avatar
Interested
hijo202 is offline
post #8 of 28 Old 06-15-2014, 08:29 AM
ZMANN's Avatar
Quoted: 1669 Post(s)
just a few thoughts
the sd has a massive caliper bracket that bolts to the knuckle and then caliper bolts to that it's all Metric IIRC not sure what the OBS uses or if that impacts you
the SD rotor diameter may effect you ? I have a set in the shed if you need a measurement ? EDIT i see you posted 8 thou that seems
unlikely ?? i thought they were much larger ?? what about thickness I think my rotor has that marked if you need it ?
the valving may be off since the SD has 2 large pistons , just a consideration
good luck it would put a huge damper in the rebuilt sd caliper cores if this works out LOL
We Miss you Ronnie
ZMANN is offline
post #9 of 28 Old 06-15-2014, 10:44 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The OBS has 2 piston caliper, how much bigger is a SD one ?
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 28 Old 06-15-2014, 11:22 AM
ZMANN's Avatar
? i thought it was a single
good question I wonder how big the pistons are ?
We Miss you Ronnie
ZMANN is offline
