2003/1996 7.3 Swap - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-12-2014, 11:22 AM Thread Starter
2003/1996 7.3 Swap
I have a totaled (complete and running) 2003 F-250 with a 7.3 PS with 130,000 miles on it. I want to put that motor in my 1996 F-205 with a 7.3 PS that has 320,000 miles on it. They are both automatics. What all is involved in making the swap. I'm thinking on just using the doner motor for the long block. Am I on the right track or is it feasible to use the newer ECM, air intake system... I don't want to get into a bunch of custom fitting/fab work, combining wiring harnesses, adapters... What parts will I need to do the swap? Seems like it should be pretty a simple swap or is their something I don't know about yet?
MichaelSD1964 is offline
post #2 of 8 Old 06-12-2014, 11:50 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The biggest problem is the fuel pump. 94-97 is a mechanical one driven off the cam in the valley of the engine. The 99-03 is a electric one.
Other than that, it is a direct bolt in using your accessories
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 8 Old 06-12-2014, 01:09 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Should be able to set the whole long block in. You will have to do e fuel and swap injectors (best just to buy new/remains because your 320k injectors are shot) and uvch's. Swap over your accessories and boom your done. I'm not sure if you can keep the turbo from the 03. It would be nice and then you could run an inner cooler.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 8 Old 06-12-2014, 02:54 PM Thread Starter
Do I leave the e-fuel pump or injectors in from the 2003 or do I need a different set up? Do I have to time the e-fuel pump with the cam, tie into the CPS?
post #5 of 8 Old 06-12-2014, 04:59 PM
the baconator
terryknight's Avatar
Quoted: 148 Post(s)
look into some of the e fuel swaps on here. most people delete the bowl and run the pump and filters under the truck. i can do that, but i see no reason you can't use the stock SD system.
your new motor will have PMR rods as opposed to forged rods, a 17* HPOP as opposed the a 15*, use the IC from the superduty though the pipes need some tweaks or use the OBS turbo set up, and you need to do something with the injectors
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 8 Old 06-12-2014, 06:19 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
2003/1996 7.3 Swap
You can't run you 03 injectors with your 96 computer. 03 are split shots and your 96 is single shots. The tuning is different. That's why you have to use your 96 injectors in your 03 block or upgrade to some 160/0 or 160/30 single shot injectors. Your stock on your 96 are 120/0 and the 03 are 140/0. As for e-fuel I would keep the 03 fuel bowl and lines down to the frame and get your fuel pump from the 03 and hook it up after your selector valve. Use part of the wiring harness for the fuel pump to wire in your pump. You can also rob the fuel cut off switch also. It's behind the passenger side kick panel. There is a few threads on how to add a relay to your fuse box also. If you do it this way you will only have a few bucks into e fuel. The big set back is the cost of injectors. I found a full set of new full force injectors160/0 for a good price from a member here. He also caries powerstruck.
01 f-250, Standard
sbluke55 is offline
post #7 of 8 Old 06-12-2014, 06:22 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Talk to hucory for injectors. He is a vender on here.
01 f-250, Standard
sbluke55 is offline
post #8 of 8 Old 06-13-2014, 06:09 AM Thread Starter
Thanks for all the help from everyone. This is all great info and pointed me in the direction I need to go.
