Fuel Pressure Port - 97' F250 - Where is it? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-10-2014, 05:43 AM Thread Starter
I watched a video, on youtube, on how to check my fuel pressure. It involved installing a schrader valve into a fuel port. I guess the powerstroke in this video was a later model because I can't seem to find any fuel port on mine . Anyone here have 97' that can share how they do it?
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 5 Old 06-10-2014, 08:56 AM
roadanarchy's Avatar
Mike,
I don't have a picture of my fuel bowl, but my 97 has a schrader valve on it already.
The pictures here http://www.dieselorings.com/docs/OBSFuelBowlRebuild.pdf might help you out.
I haven't measured my fuel pressure, but it appears that the schrader valve is after the fuel regulator so it should give you the info you need.
1997 Ford F250
146K Stock Miles
Hiniker 9850 V-Plow
roadanarchy is offline
post #3 of 5 Old 06-10-2014, 09:18 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
One of three things it could be. The guy in the video has e-fuel conversion, PO of your truck already did e-fuel conversion, or your not looking hard enough.
Its under the engine cover to the right of the fuel bowl theres what looks exactly like a tire valve stem cover screwed onto it.
Either post the video or a pic of your engine bay with the cover off and that will give the answer right away
Originally Posted by roadanarchy View Post
Mike,
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 5 Old 06-10-2014, 01:08 PM Thread Starter
Found it! ..thank you. Just like you said: Tire stem cover. I was thinking it was a port on the bowl itself.
Now I just need a 90 adapter so I can get my fuel pressure gauge hose on .... Anyone know the size?? ...my helminc.com manuals haven't arrived yet so I can't look it up.
Mike
post #5 of 5 Old 06-10-2014, 03:56 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
The port in the regulator is 1/8 NPT. Be careful not to overtighten it as the regulator body cracks easily. Hopefully you are not planning a permanent gauge installation. They cannot handle the pulses from the mechanical fuel pump and usually short order. Cheers!
Patrick Feeley is offline
The Following User Says Thank You to Patrick Feeley For This Useful Post:
mikeallenbrown (06-11-2014)
