Fuel Bowl Rebuild - Broken Snubber (96-97 Only) - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-06-2014, 07:33 AM Thread Starter
roadanarchy's Avatar
I was in the process of rebuilding my fuel bowl with DieselORings Kit #6-002. When I first disassembled the regulator assembly, the plastic snubber fell out easily. I pushed it back in so I would not lose it. When I got around to cleaning it a while later it would not come out. I used a pick tool to GENTLY pry it, but to no avail. In the process, a couple of the tabs broke and it is still in there. So much for gentle...
The snubber in question is shown in the 2nd picture down on page 5 of Guzzles Instructions: http://www.dieselorings.com/docs/OBSFuelBowlRebuild.pdf
Can I leave this in there "broken" without trouble or do I need to track down a plastic snubber and remove the broken one?
To be clear, the snubber itself is not broken, just the "tabs" on the bottom of it. If these are critical to the function, then I guess I will have to admit the snubber is broken.
1997 Ford F250
146K Stock Miles
Hiniker 9850 V-Plow
Last edited by roadanarchy; 06-06-2014 at 02:19 PM. Reason: Error correction: would NOT instead of would
roadanarchy is offline
post #2 of 6 Old 06-08-2014, 08:50 AM Thread Starter
It turns out this part is just to remove pressure spikes from the mechanical fuel pump. Having the tabs broken off won't affect function.
If anyone else has this problem, I hope this helps.
1997 Ford F250
146K Stock Miles
Hiniker 9850 V-Plow
post #3 of 6 Old 06-10-2014, 05:49 PM
whiskey-d's Avatar
Are you replacing the rubberized lines that attach to your fuel bowl? I pulled my bowl to get the hpop out and was thinking of replacing those little stubs of hose and hose clamps while its all apart but when I went to the parts store the guy there said that he thinks they are high pressure lines and the stuff he had wouldn't hold up. Called a specialty diesel shop to see if they had some and he said he thinks it max 30psi and any fuel hose should work fine…. shoulda came here first but do you know the specifics of those lines? the old ones are kinda brittle and I do not want to put them back in. Don't mean to jack your thread just hoping you'd know. Thanks
whiskey-d is offline
post #4 of 6 Old 06-10-2014, 08:44 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
You can get the stubs of hose from Ford or someplace like DieselOrings.com. High Pressure Fuel Injection Hose that is rated for diesel will work too (it is readily available at most auto parts houses, 5/16" and 3/8").
Fuel Pump Hoses
(Ford) F4TZ-9324-BA (Black Hose, 1 required)
(Ford) F4TZ-9324-CA (Longer Blue Hose, 1 required)
(Ford) F4TZ-9324-DA (Shorter Blue Hose, 2 required)
(Aeroquip) FC498-06 (Blue Hose)
Cheers!
Patrick Feeley is offline
post #5 of 6 Old 06-10-2014, 09:47 PM
whiskey-d's Avatar
thanks Patrick
post #6 of 6 Old 06-12-2014, 06:48 PM
I tried to remove the snubber when I had mine apart and broke one of the tabs. After I kicked myself in the butt, I put it all back together and have been running fine ever since. I do wonder if, in some manner, it might affect fuel mileage.
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
