Twisted frame??? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 06-05-2014, 10:44 PM Thread Starter
chaneye1's Avatar
Quoted: 24 Post(s)
Twisted frame???
My truck since I bought it has had a lean to the passenger side, originally thought it was leaf springs and I wanted to level out the truck so I replaced the springs, come to find out that was not the problem, truck still leaned, so I pulled passenger side springs again and put a half inch spacer underneath the springs, this helped tremendously, taking the sag from an inch to a half inch.... Next I checked body mounts and from what I can tell they look and measure all about the same give or take 1/8" but none was collapsed...Just seeing if anybody had any other ideas or not, I'm beginning to believe it's a twisted frame, but wanted some other opinions... Thanks in advance
1997 7.3 powerstroke, mbrp 4 inch turbo back, ts 6 pos chip, 6637 air filter
chaneye1 is offline
post #2 of 24 Old 06-06-2014, 01:06 PM Thread Starter
chaneye1's Avatar
Quoted: 24 Post(s)
Anybody have any other ideas?
chaneye1 is offline
post #3 of 24 Old 06-06-2014, 04:58 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Passenger rear body mount. VERY common to sag right out
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 24 Old 06-06-2014, 05:00 PM Thread Starter
chaneye1's Avatar
Quoted: 24 Post(s)
I'll check them all out again, all the body mounts measured very close, I'll check it again, thanks a lot!! Good lookin truck btw
chaneye1 is offline
post #5 of 24 Old 06-06-2014, 05:29 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Has to be a Ford thing. Every truck I have owned leaned to one side or another. Always have problems with the leafs, many cracked, I just go out and get helper springs or add a leafs, usually mostly levels out the truck, same with the front, I put a couple of long springs in the front and back and as ugly as the truck sat, it now sits pretty good. Never heard of a truck with a twisted frame unless something major happened like a bad wreck or the truck somehow got racked by some position it was in.
dirtcrew51m is offline
post #6 of 24 Old 06-06-2014, 06:08 PM Thread Starter
chaneye1's Avatar
Quoted: 24 Post(s)
Thanks for the reply, that's the bad thing about my truck, original owner reported it stolen... He turned out to be the thief had it painted and tore all the id stickers off the door jamb and ripped the vin plate off, so no car fax for me haha, for all I know it's been wrecked but I'll never know, I'll replace the body mounts next, how bad is that job?
chaneye1 is offline
post #7 of 24 Old 06-07-2014, 01:46 AM
Quoted: 4 Post(s)
Don't even bother "checking" it, just REPLACE them. They are 15-20 years old, they are SHOT
post #8 of 24 Old 06-07-2014, 03:00 AM Thread Starter
chaneye1's Avatar
Quoted: 24 Post(s)
How big of job is it to replace?
chaneye1 is offline
post #9 of 24 Old 06-07-2014, 07:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Do you have a title?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 24 Old 06-07-2014, 07:52 AM Thread Starter
chaneye1's Avatar
Quoted: 24 Post(s)
Yes truck was re-issued a Georgia state vin number when it was found
chaneye1 is offline
