vacuum pump pulley. should it turn freely? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-05-2014, 12:26 PM Thread Starter
Hey guys,
quick question about the vaccum pump pully on my '96 OBS. I went to replace the serpentine belt this afternoon and was checking all the pulley to make sure they turned freely. The A/C, idler, etc all spin freely but the vacuum pump one does not turn at all. Is that how it should be? Should it resist a hand turn?
Thanks for the help.
'96 F-250, 230k
Custom SVO Conversion (check valves)
On board filtration
80k SVO miles and counting!
CharlieC is offline
post #2 of 14 Old 06-05-2014, 12:35 PM
Quoted: 53 Post(s)
It should hand turn, with some resistance. You'll feel the resistance go up and down as you turn it, and the diaphragm does its thing. But it sure shouldn't be so tight that you can't turn it by hand.
madpogue is offline
post #3 of 14 Old 06-05-2014, 07:15 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
+1. You need a new vacuum pump.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
post #4 of 14 Old 06-06-2014, 06:42 AM
Quoted: 9 Post(s)
Trust me. Replace the vacuum pump and get the one that comes with a new pulley. My vacuum pump just put me and my 5th wheel on the side of I-40 in New Mexico. It threw the bearings out of the pulley and shredded my belt. It took 2 wreckers to get me off the hi way. One towed me 60 miles to the only Autozone that had the pump with pulley. Trust me after that experience spend the extra coin and save yourself 5 hours on the side of the road.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #5 of 14 Old 06-06-2014, 07:22 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
My vacuum pump does not have a bearing on the pulley it is in the pump itself. You must have a diff. setup.
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #6 of 14 Old 06-06-2014, 07:28 AM
PhilMac's Avatar
bearings are in the pump. When they go, you're done...replace it if its that hard to turn.
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
PhilMac is offline
post #7 of 14 Old 06-06-2014, 08:55 AM
Quoted: 53 Post(s)
None of them have bearings in the pulley, by definition. The pulley has to turn the shaft.
The replacement pump that comes with the pulley must be the Cardone 64-1029, and it has (as it would have to) the bolts already in the bolt holes, captured behind the pulley. That's a reman pump, and Cardone's reputation for quality is right "up" (ahem) there with Dorman's. There are a couple of online sellers, accuratediesel.com being one of them, that carry new (not reman) pumps. All you need is a power steering pulley tool, which is cheap at Harbor Freight, or can be borrowed for a deposit from your FLAPS. Depends on how quickly you need to be back on the road.
AZ has a _new_ Cardone pump, without the pulley, for less than the reman one with the pulley.
madpogue is offline
post #8 of 14 Old 06-06-2014, 09:10 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
When mine went out, I got an OEM one from Ford. cost 219.00
post #9 of 14 Old 06-06-2014, 10:21 AM Thread Starter
Thanks for all the replies. Y'all were right. Fired up the truck this AM to go buy a new vacuum pump and the pump blew and shredded the belt on the way to the store. At least it happened in town and not on the road. That pump only lasted me 30 months, just barely out of warranty. Lesson learned.
'96 F-250, 230k
On board filtration
CharlieC is offline
post #10 of 14 Old 06-06-2014, 01:15 PM
Quoted: 53 Post(s)
You could've prevented shredding that new belt if you'd heeded the advice before starting the truck. Or did you put the old belt back on for this trip?
The creepy ad-bot strikes again; banner ad indicates the Cardone 64-1029 for $89 on amazon. Amazon has had some good prices on auto parts lately, usu. with free shipping. Now if only they could get that 30-minute drone delivery thing figured out.....
madpogue is offline
