Is dually Rear diff carrier and gears same as SRW? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-05-2014, 06:52 AM Thread Starter
cthom388's Avatar
I have a 1996 f350 dually parts truck with a ls rear axle, what i am wondering is can i take the carrier out of the dually axle and put it in my single wheel axle? They are both 4:10 as well.
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #2 of 9 Old 06-05-2014, 07:00 AM
ZMANN's Avatar
Quoted: 1900 Post(s)
nope not the same axle
look at the dif cover
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 9 Old 06-05-2014, 01:18 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
yes they are same.
the 250/350 OBS trucks all had a sterling 10.25 the F-Superduty got the Dana 80.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #4 of 9 Old 06-05-2014, 02:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The answer is yes, it's a sterling 10.25 either way
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 06-05-2014, 03:43 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
They are the same (repeating what the others said), 10.25 Sterling. My 94 DRW was a 4.10 10.25 Sterling. The OBS F-SuperDuty's had the Dana 80 (I think). Cheers!
Patrick Feeley is offline
post #6 of 9 Old 06-05-2014, 04:00 PM
ZMANN's Avatar
no chit ?
sorry bout that
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #7 of 9 Old 06-26-2014, 06:52 AM Thread Starter
cthom388's Avatar
Thanks guys sorry i been away for awhile. So could i just put the whole axle under my truck and remove the adapters? Im just wanting the limited slip option.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #8 of 9 Old 06-26-2014, 10:01 AM
the baconator
Quoted: 153 Post(s)
dually axles are wider than SRW axles
post #9 of 9 Old 06-26-2014, 01:40 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The carrier is the same, the housing and shafts differ
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
