Here's the issue. I have a 96 F250 with the 5 speed ZF transmission S5-47 type. I am told this was made by Mazda. There is a sticker on the side to the trans that says Use ONLY Mercon synthetic or equivilent. I could not find so I went to the Ford dealer and asked about it. He said they usually use Mercon V which is synthetic. He also said that they make a special fluid but it is about $20 a quart, that is why they use the Mercon V. Any thoughts on this?
The fluid that is in the trans is green colored. I have no idea if it has ever been changed. Anyone know anything about this? Thanks, Jason |
anybody know? im wanting to service the tranny in my 97 PSD. not sure if its the same as above. just looking to find out what to use and if i can use synthetic? not sure when the last service was so i rather be safe than sorry.
thank's FatMan |
bump
Use dexron/mercon III automatic trans fluid.
can i use that in a synthetic blend?
the mercon 5 is synthetic, but very costly. Mercon 5 will replace any type mercon atf.
you da man thank's.. im not to much worried about the cost cant be to much more per qt than freakin syn gear lube these days.
