Wierd Issue when coming to a stop. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-04-2014, 05:46 PM Thread Starter
The truck when I first start (first 2-5 seconds) idles rough and sounds really lopey and choppy or very fast inconsistent idle. But like mentioned only the first couple seconds after crank then evens out. Same thing happens when I am driving and I push in the clutch when coming to a stop or when stopped and the truck goes into idle, real rough then it will push through and even out a couple seconds later. Doesn't do this all the time mainly when starting the truck after it turns over and when coming to a quicker stop. Any ideas?
Truck has 175/80 PIS Injectors, rebuilt the turbo, and new Napa filter with K&N tubing as of March. Still running a Ford Racing clutch and Dual Mass Flywheel. Someone mention it could be the play in the dual mass flywheel?
Could it be the FPR filter or fuel related?
Thanks in advance!
T0RCH3D is offline
post #2 of 12 Old 06-04-2014, 06:25 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 347 Post(s)
Dual mass will clatter ALOT if its no good at an idle in neutral.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 12 Old 06-04-2014, 07:54 PM Thread Starter
Will in change the idle anyway or just make a clatter sound? Mine does the sometimes when I depress the clutch quick at higher RPMs when coming to a stop. Wondering if the idle thing is related or different, also is this something I should be concerned with and fix ASAP or run it until it fails type situation?
T0RCH3D is offline
post #4 of 12 Old 06-04-2014, 07:59 PM
LoxDiesel's Avatar
Quoted: 347 Post(s)
Nah dual mass shouldn't mess with the idle it will just clatter obnoxiously. You'll replace it long before it fails. It will get so bad you cant stand it. Do you have the latest and greatest cps?
@loxdce
post #5 of 12 Old 06-04-2014, 08:11 PM Thread Starter
No I do not, owned the truck since October of last year and didn't get to that yet? Wouldn't a bad CPS cause more more constant issues instead of at certain times. Truck has 103K on it now btw. What CPS would be worth looking into, how to change, and what are the symptoms of a bad one? Wouldn't the truck not start if that were the case.
T0RCH3D is offline
post #6 of 12 Old 06-05-2014, 09:09 AM
leojr's Avatar
Quoted: 4 Post(s)
Check your oil level. It could be low enough to starve the HPOP during a stopping event.
Don't ask me how I know...
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #7 of 12 Old 06-05-2014, 09:42 AM Thread Starter
Oil level is good, thanks for the suggestion. It does make me think though, the truck was running on dangerously low oil level when my oil pan had a hairline fracture that finally gave. Was only running about for a few minutes before I shut her down. What are the effects of a bad HPOP? Everything seems to be running fine other than that.
T0RCH3D is offline
post #8 of 12 Old 06-15-2014, 12:22 PM Thread Starter
Bump...what could this be?
T0RCH3D is offline
post #9 of 12 Old 06-15-2014, 02:44 PM
problemchild55's Avatar
Quoted: 2 Post(s)
My truck and a buddy of mines truck do it to. I just learned to ignore it but I am curious to know what's causing it.
problemchild55 is offline
post #10 of 12 Old 06-15-2014, 07:31 PM Thread Starter
Do you still have a dual mass or have your or your friend went to single mass flywheel. I was told that could be the culprit but don't fully believe it..
T0RCH3D is offline
