Powerstroke Greenhorn here - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-03-2014, 08:10 AM Thread Starter
Hey All,
I recently decided to park my cummins and get workin on my powerstroke again. I know a whole hell of a lot more about the cummins than I do about the powerstroke so I am looking for some guidance. I have a 94.5 F-350, 5 speed, single cab, flatbed, 285,xxx, banks powerpack, 4" MBRP. My father bought it brand new in 95 for his concrete company and it was my first truck when I was 16. At some point I jumped on the Cummins bandwagon and that was a lot of fun (and money) but I have been missing the old hog. I remember when I parked the powerstroke I had a few questions. First, the banks turbo housing f***ed with the EBV. How hard/expensive is it to delete the EBV. I have all kinds of wire trying to hold it open but im not sure if its working. 2nd, it peaks at 15lbs of boost. Is this because of the ebv being open or does this number sound normal. I am used to seeing a lot more boost in my dodge so i find it concerning
Thanks,
Kelly
Kellysap1989 is offline
post #2 of 14 Old 06-03-2014, 03:01 PM
Quoted: 2 Post(s)
The EBV isn't a big issue unless it sticks closed or something, and you'll know it - you will have a gutless wonder. As long as it's open and staying open, no real need to mess with it more.
15psi sounds reasonable for a stock truck. Maybe a bit low. Check for intake & exhaust leaks. But with nearly 300k miles, if it's got stock injectors, that's probably fine.
Syonyk is offline
post #3 of 14 Old 06-03-2014, 03:34 PM
ThreeFitty's Avatar
Quoted: 3 Post(s)
My e99 puts out about a max of 17 I have seen so far so I wouldn't be worried about the boost. To delete the ebv isn't too bad of a job from what I've read but it's not a necessity, I would keep it in place if you live some where it gets cold.
e99 F350 SRW 4x4 RCLB 7.3 Diesel (3/98)
-5" Diamond Eye Exhaust, straight piped
-RiffRaff 6637
-Sinister Diesel Coolant Filtration
-Hopefully a tune soon
2011 F350 SRW CCSB King Ranch (3/10)
-GearHead Tuned, No Limit Fab intake and other shiny thingies, H&S Cold Side pipe, still needs one of them whistler units
ThreeFitty is offline
post #4 of 14 Old 06-03-2014, 04:23 PM
Quoted: 28 Post(s)
15 psi on stock settings is reasonable with those miles. If you're only hitting 15 psi in highest setting than you got some leaks. Check your intake boots for cracks or tears and inspect uppipes for exhaust leaks (soot streaks on pipes or soot on firewalls). Also how does the turbo wheel look?
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #5 of 14 Old 06-03-2014, 10:48 PM
dr.deere's Avatar
Quoted: 19 Post(s)
15 psi is not reasonable in my opinion My 94 has 290k in the clock and I can hit 23 psi easily if I run it up to yellow line on tach. I would say if you can't do that you have an preturbo exhaust leak somewhere in the exhaust or turbo to intake plenum leak.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #6 of 14 Old 06-04-2014, 03:00 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Highest I'm hitting is 12 psi, 316k ww2, ts canned tunes, and I just fixed my exhaust leak, this number is pulled from my map sensor via the PCM and displayed on my infinity
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 14 Old 06-04-2014, 04:02 AM
ThreeFitty's Avatar
Quoted: 3 Post(s)
23psi on a stock setup!? Damn!
-RiffRaff 6637
post #8 of 14 Old 06-04-2014, 04:38 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I saw those numbers on my Cali model with canned tunes, it has bigger injectors, how do you see those numbers?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 14 Old 06-04-2014, 05:02 AM
dazed01's Avatar
Before I did injectors, exhaust and a tune the highest my boost gauge would see was 10. now it will run up past 30 if I let it.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #10 of 14 Old 06-04-2014, 05:23 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I'm taking that reading off a boost gauge t-d into a map line my 97 with fresh motor will 25. Like I said I have to take it all the way to the yellow line in the tach to get there though
dr.deere is offline
