Cheapest way to level out my 95 Powerstroke, with stock Dana 50, ideas? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-02-2014, 08:52 PM Thread Starter
If anyone has any ideas or suggestions id love to here them
OBS Powerstroke is offline
post #2 of 8 Old 06-02-2014, 09:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are you nose high or rear high? And by how much, if rear high a DIY aal will do the job
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 06-02-2014, 09:17 PM Thread Starter
the back is higher, I got 285/75/16 on it right now so like 32"s or so, and rubs a bit, just want level it out
post #4 of 8 Old 06-02-2014, 09:19 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Make a do it yourself add a leaf up front, it will bring it up as many springs as you stick in, or have the stock ones re arched
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 8 Old 06-02-2014, 09:23 PM Thread Starter
my buddy just put in a 4" rough country lift, and he has his old stock front springs, could I use those?
post #6 of 8 Old 06-02-2014, 11:29 PM
JSchuricht's Avatar
You don't want to lift a TTB axle without dropping the center support. For a cheep leveling setup, ditch the rear blocks. Probably not the look your going for but for the cost of 4 ubolts it's hard to beat.
Only pic I could find of mine before the D60 and lift. I never measure it but it looked level.
JSchuricht is offline
post #7 of 8 Old 06-03-2014, 03:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I leveled mine with a solid axle swap and stock f350 springs, but it was like $500, you don't want to use the f350 springs on the f250 axle, they are it designed to twist and may lead to premature failure
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 8 Old 06-03-2014, 06:14 PM
toad's Avatar
Quoted: 16 Post(s)
I used a Zero Rate add a leaf from Off Road Design. Try to keep the ride as nice as possible. The problem is the alignment afterwards. I used some adjustable camber bushings to get mine within spec. You can also use drop brackets for the axle pivots. All that has be tossed now. Truck has F350 springs and a dana 60. I still have the Zero Rates if your interested.
Add a Leafs, Zero Rate for 4x4 Suspensions from Offroad Design
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
