Slightly erratic idle - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-08-2008, 04:06 PM Thread Starter
Question Slightly erratic idle
Gentlemen,
My 97 F250 has been idling funny lately. It fluctuates about 50 to 75 rpm, and sometimes it's just fine. Runs great otherwise. Changing fuel filter makes no difference . Is this a pre-cursor to impending doom? Any thoughts greatly appreciated. Idle fuel pressure is approx. 60 to 70 psi..
1997 F250 7.3L Krew Kab, Short box, Red&white
Banks Git-Kit, K&N Air Filter, Bypass oil filter,
Gutted Cat & muffler delete, 3 Pillar Isspro gauges: boost, pyro, trans. FPR shimmed, Marshall fuel pressure gauge under hood. 170K
otterdriver is offline
post #2 of 13 Old 12-08-2008, 04:26 PM
nicho's Avatar
Send a message via AIM to nicho
50 rpm up or down?
Searching :
F-350
1994-1997
DI 7.3 Turbo
Extended or Crew Cab
4x4
Manual Transmission
If you are willing to part with yours on the cheap, help a college student out.
nicho is offline
post #3 of 13 Old 12-08-2008, 04:27 PM
OregonStroker's Avatar
try the fuel plate mod? my dad has a 95 that does that a little only when first starting tho. sometimes longer than others. I have heard increse in line pressure helps idle issues with the OBS OBD1 computer system. Im sure a techie will know exactly what u need.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #4 of 13 Old 12-08-2008, 04:35 PM Thread Starter
It usually seems to drop DOWN just a bit. I'm not familiar with the fuel plate mod. Any thoughts on it possibly being the ICP sensor?
post #5 of 13 Old 12-08-2008, 05:09 PM
Nuckin' Futz
im apt to say welcome to the wonderful world of the OBS. Mine does the same thing. These trucks were the first of any computer controlled diesel (well in '94.5 they were) so the control over the engine tends to be a bit slow so the computer catches itself. Mine has done it for three years so i wouldn't be to worried about it. Id be willing to bet you see it more prominently after a long highway run or pulling a good load. I just tell myself its black betty (my truck) not wanting to stop its champing at the bit. It sounds like fuel pressure and everything else is where it needs to be so like i said don't worry about it...keep and eye on it but don't worry about it. I know that its kind of annoying though.
Turbodude is offline
post #6 of 13 Old 12-08-2008, 05:25 PM Thread Starter
OK, I think I can just live with it. Whats your take on a high pressure oil crossover? I've heard these can make idles smooth out. My engine also has a slight shudder to it while idling. And Turbodude, thank you for serving our country in the military!.. Chris
post #7 of 13 Old 12-09-2008, 06:27 AM
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
doing the fpr shim helps some, but i know what your talking about. rpms kinda dip down a bit close to the 500rpm line, then back up. its similar to if the a/c compressor was coming on and back off.
mine only does it when the engine is cool
it'll be fine though
Typical cummins owner.
taylorking is offline
post #8 of 13 Old 12-09-2008, 06:54 AM Thread Starter
Thank you, T-Bone, I will try the FPR mod as I am familiar with that. Yep, same symptoms as you describe. I have a Marshall fuel pressure gauge mounted where the schraeder valve normally resides, so it will be easy to see what sort of a pressure reading I end up with. Thanks for the reply. Merry Christmas out there in NC. Chris
post #9 of 13 Old 12-09-2008, 12:03 PM
Too cool for school
taylorking's Avatar
let us know if it helps any
you will get a tad bit extra smoke too, i can flip my chip to stock and see a faint bit when i put the hammer down.
post #10 of 13 Old 12-09-2008, 12:58 PM
z250kid's Avatar
the cross over hose its okay not much of a difference little smoother on my 96
but easy to install but move the hpop line was a pain in the *** but a little more throttle response at higher rpm about 1500+
1996 F350 4x4 Powerstroke Diesel
Afe Stage 2
3 Inch Downpipe,Cat-Delete,90 degree elbow(ss)
Diy Exhust Brake
Hpx Crossover
z250kid is offline
