OBS chat - Page 6455 - Ford Powerstroke Diesel Forum
 487Likes
post #64541 of 118542 Old 10-13-2011, 06:38 PM
Powerstroke Techie
forddieseldoctor's Avatar
It was stuck to the line. I had to pry mine off of the line when I changed my pump.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #64542 of 118542 Old 10-13-2011, 06:44 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 121 Post(s)
no washers
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #64543 of 118542 Old 10-13-2011, 06:48 PM
Powerstroke Techie
Check out this pic. I know it's crappy, but #5 is the pump, #16 is the line (shown with the cali emissions fuel pulse damper on it) #15 is the bolt and #14 is the sealing washers. They show one on each side of the line.
Meet Double Aught
2000 F250
post #64544 of 118542 Old 10-13-2011, 06:50 PM
Powerstroke Techie
Here's the description for the numbers in the pic.
Item Part Number Description
1 9155 Fuel Filter
2 9C334 Fuel Tube Clamp
3 9324 Fuel Filter Supply Hose
4 9E313 Fuel Shield
5 9350 Fuel Pump
6 9N693 Fuel Pump Seal
7 - Fuel Pump Tappet (Part of 9350)
8 9D308 Fuel Return Hose
9 9D308 Fuel Return Hose
10 9C330 Fuel Pump Supply Tube
11 Fuel Supply and Return Tube Clamp (Part of 9C330)
12 9A564 Fuel Return Tube
13 Fuel Supply and Return Hose Clamp (Part of 9C330)
14 Fuel Pump Fitting Gasket (Part of 9A555)
15 Fuel Pump Outlet Bolt
(Part of 9A555)
16 9A555 Fuel Injection Tube
17 45-Degree Street Elbow (Part of 9A555)
18 45-Degree Street Elbow (Part of 9A555)
19 Oil Deflector (Part of 9F593)
20 Bolt (Part of 9F593)
21 9F593 Fuel Injector
22 Fuel Injector Hold-Down Clamp (Part of 9F593)
23 Backup Ring
(Part of 9F593)
24 Cushion Ring
(Part of 9F593)
25 Fuel Injector Upper Seal
(Part of 9F593)
26 Fuel Injector Middle Seal
(Part of 9F593)
27 Cushion Ring
(Part of 9F593)
28 Fuel Injector Lower Seal
(Part of 9F593)
29 Fuel Injector Gasket
(Part of 9F593)
30 9N693 Elbow and Plug O-Ring
31 9E629 90-Degree High-Pressure Hose Elbow
32 9K260 Fuel Line Sleeve
33 9N653 High-Pressure Manifold Supply Hose Clamp
34 9D308 Fuel Return Hose
35 Fuel Return Connector (LH) (Part of 9D308)
36 9A332 High-Pressure Oil Pump Supply Hose
37 Elbow (Part of 9A543)
38 9C968 Injection Pressure Regulator
39 9K319 Connector
40 9417 High-Pressure Oil Pump Flange Gasket
41 9A543 High-Pressure Oil Pump Assy
42 9K260 Fuel Line Sleeve
43 9N653 High-Pressure Oil Pump Supply Hose Clamp
44 9N320 90-Degree Fuel Return Elbow (RH)
45 9J323 High-Pressure Oil Pump Supply Hose
46 9N332 90-Degree High-Pressure Hose Elbow
47 9K024 Supply Rail Plug with O-Ring
48 390147-S Straight Connector
49 9D308 Fuel Return Hose
50 9K260 Fuel Line Sleeve
51 9N320 Fuel Return Hose Elbow
52 9N320 Fuel Return Hose Elbow
53 9K260 Fuel Line Sleeve
54 9324 Fuel Filter Water Drain Hose
55 9L273 Water Drain Tube
56 9C334 Fuel Tube Clamp
57 9W310 Water Drain Tube Clip
Meet Double Aught
2000 F250
post #64545 of 118542 Old 10-13-2011, 07:07 PM
Gertrude's Avatar
Send a message via Skype™ to Gertrude
oh wow, thanks!!!!
Andy=23
Future Mods: Project Revive/Rebuild/Restore
Too many cars, not enough money.
Gertrude is offline
post #64546 of 118542 Old 10-13-2011, 07:13 PM
Buffalo444's Avatar
How hard are IDI's to work on? there's no pcm right?
Jason
First rig: e99 F250 CCSB 4x4 auto, white, 388k miles: traded in
Then: 02 F350 RCLB SRW 4x4 zf6, silver, 201k miles, THREW A ROD
: traded to Jake
Now: 96 F350 CCLB DRW 4x2 auto, red and silver/grey, 266k miles: rusty but trusty
Buffalo444 is offline
post #64547 of 118542 Old 10-13-2011, 07:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's like carberater compared to fuel injected with idi vs Di
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #64548 of 118542 Old 10-13-2011, 08:13 PM
Buffalo444's Avatar
so essentially, you can SEE everything, no worries as far as electrical problems causing engine malfunction?
Jason
: traded to Jake
post #64549 of 118542 Old 10-13-2011, 08:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Just about, the wiring in the idi version is a fraction of the psd, no where near as much stuff.
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #64550 of 118542 Old 10-14-2011, 03:56 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Yep x2 on there being x2 washers lol.
I ended up changing my whole fuel pump to make that leak stop. Tried two sets of washers first but the sucker kept dripping. Sounds bizarre but the old boy I part time for suggested it and he was right. Apparently the fitment between the bolt, the fitting and the pump just goes catawampus.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
Tags
1994-1997 , 6.0's suck , awesomeness , chooo chooo crash , derail gods , derail what? , facebook for men , garrets home land , multi-quote what? , no snapperheads , obs , old body style , old but sexy , old but slow , old but superior
