EXHAUST IN CAB - Ford Powerstroke Diesel Forum
Old 12-02-2008, 06:25 AM
EXHAUST IN CAB
Well on the way home last night i noticed exhaust smell in the cab with the blower running so i guess its time to pull the motor and do the oil pan and all exhaust gaskets and seals. Dam i hate the thought of doing that this time of year.
Old 12-02-2008, 10:49 AM
Send a message via AIM to kx592
Wow, thats a real bummer man..Are you sure you have to do all that just casue the smell? Check for oblivious stuff first?
Old 12-03-2008, 04:06 PM
Only with the blower motor running? Or worse when the blower's on.
Check your shift boot... and of course, your exhaust.
Old 12-03-2008, 05:27 PM
i know if you remove the splash sheilds you can get to the exhust manifold really easy
if its faint then dont worry till spring
Old 12-03-2008, 05:36 PM
I bet it's the donut gaskets. That happens to alot. It's still a PITA.
Old 12-03-2008, 05:38 PM
duct tape & zip ties
You up pipes most likely leaking. Best way to fix it is get the bellow pipe kit from itp or other vendor.
