i thought starter relays would work for gpr's? - Ford Powerstroke Diesel Forum
Old 12-01-2008, 04:00 PM
i was told a sterter relay would work for a gpr,not for very long but it would work for awhile,so i buy one and it is set up so power in and power out on the small terminals,so the relay is always energized,then when you switch the wires,its always dead? what gives man
Old 12-01-2008, 04:39 PM
snyone with some info
Old 12-01-2008, 06:12 PM
a friend of mine did that and it didn't work, they work differently, the gpr is suppose to send 12v to the glow plugs from the battery when turned to "wait to start". the starter relay isn't setup to do that. it won't send power when turned "wait to start".
Old 12-01-2008, 06:15 PM
duct tape & zip ties
A starter relay is not designed for this type of use.
Old 12-01-2008, 08:42 PM
Electrical Ogre
In addition, the starter relay coil is grounded to the mounting flange, requiring a positive input fron the key. The GPR has two coil terminals, one for ignition positive (hot in run,) the other to PCM, which provides a switched negative to turn the coil on/off.
Old 12-01-2008, 08:54 PM
yepp, just not going to work, or it may start a small fire
Old 12-02-2008, 02:44 PM
yea it just kept them on constantly,so i bought a real gpr,oh well,thanks though
