fuel bowl heater on '96? - Ford Powerstroke Diesel Forum
Old 11-30-2008, 06:29 PM
Hey guys,
Just brought my '96 into the garage for a service, drained the bowl to clean it and replace the filter, and I noticed it doesnt have a bowl heater like I have seen in photos.
Is this normal? Is there supposed to be a bowl heater on the '96 PSD?
thanks!
Old 11-30-2008, 06:50 PM
Shaking the Bush Boss
yea, mine has the heater. If its not there, someone probably removed when the soilder broke, and it shorted out and blew a mega fuse. If your interseted in replacing it, theres a thread here somewhere that shows you how, using one from a newer 7.3.
Old 11-30-2008, 06:57 PM
well shoot. This probably has a good deal to do with my "lazy" injectors.
For the retrofit, do you use the entire bowl from a newer PSD, or just the heater?
Old 11-30-2008, 06:59 PM
Old 11-30-2008, 07:48 PM
Powered by Deez Nuts
i broke my heater in half
the other half is still on there
will that blow a fuse?
i dont know if it even works.
Old 11-30-2008, 09:22 PM
No, use just the new heater. I think you have to drill a new hole in the bowl though.
Old 11-30-2008, 09:24 PM
Not unless its shorting out against the bowl.
The soilder broke on mine, allowing the end of the element to touch the side of the bowl, causing the short to ground.
Old 12-01-2008, 09:39 AM
Here's a .pdf about replacing the fuel bowl heater. You do not have to drill a hole for the heater, just a little bit of grinding with a dremel cut off wheel and a sharp screw driver inside the fuel bowl, but nothing hard at all. It was real easy to do. Took about 20-30 minutes to complete. I bought the heater from an International parts supplier for around $20.00 or so. Hope this helps.
Old 12-06-2008, 09:16 AM
Thanks!
