cruise control - Ford Powerstroke Diesel Forum
Old 11-29-2008, 06:48 PM
Powered by Deez Nuts
cruise control
on a 97 psd, does the cruise control require vacuum to run?
my cruse doesn't work and there is a loose vacuum hose next to the map sensor.
Old 11-29-2008, 07:31 PM
Illiana Chapter Director
Does not require vacuum. It is all electronically controlled. My switches in the steering wheel went bad on my 95 when I had it.
Old 11-29-2008, 07:35 PM
Shade tree mechanic
mine went out. figured it was just the controls in the steering wheel, ended up being a fuse in the fuse box under the hood
Old 11-29-2008, 07:38 PM
were the switches hard to replace?
Old 11-29-2008, 07:48 PM
No, it's real easy. Pull the center section (horn button) off steering wheel and you can get right to them. Definetely check all the fuses first though.
