both small terminals on gpr have power? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-29-2008, 01:40 PM Thread Starter
97powerstroker's Avatar
i wired in a on\off switch for the gp's,also wired in a relay to disengage them while cranking,but when i turn the key on,both small wires get hot.why is this.i left on of the wires on the gpr for a ground,and routed the other to the switch,back out to the relay,then out of the relay back the the gpr.so now both get power.whats up with this?
96 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #2 of 17 Old 11-29-2008, 01:54 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Wait what, I am confused. I need a graph and crayons.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 17 Old 11-29-2008, 02:02 PM Thread Starter
any one with any explanations?
post #4 of 17 Old 11-29-2008, 02:20 PM Thread Starter
when i go back towards the pcm the wire isnt hot,its grounded,just by the relay it shows power
post #5 of 17 Old 11-29-2008, 02:31 PM
Transmission or Injectors
lwillson's Avatar
I'm afraid without a picture of what you wired to what, I cant quite figure out what you've done. Can you draw it out quickly in MSPaint or something?
lwillson is offline
post #6 of 17 Old 11-29-2008, 02:37 PM Thread Starter
well now with only one small lead on the gpr,which is the power lead,with the key on both terminals are getting 12v somehow.
ok theres two small wires connected to the gpr,one is power with key on,other pcm grounds,then its energized.i left the ground wire untouched,took the power lead off of the gpr,routed to a switch inside the cab.from the switch i brought it back out to a relay.goes in the relay then comes back out to the gpr.after all of this,im getting 12v to both terminals,even if only one small wire is hooked up.
post #7 of 17 Old 11-29-2008, 02:39 PM
cchase's Avatar
if you are getting power to the GpR with those little wires off, i would say you have a bad gpr
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #8 of 17 Old 11-29-2008, 03:32 PM Thread Starter
so i took the relay out of the equation and kept the switch,heres what im getting with switch on....key on,one small terminal 12v,other small terminal .8v big terminal going to glow plugs around 10v,12v goin into relay from batt also.then once i start the truck with the switch off im still getting a reading of just under 1 v on the small wires,so why is there power there when the switch is off?
post #9 of 17 Old 11-29-2008, 03:37 PM
Quoted: 6 Post(s)
I have no idea.
post #10 of 17 Old 11-29-2008, 04:13 PM Thread Starter
any more help around?
