stock air filter question - Ford Powerstroke Diesel Forum
Old 11-26-2008, 09:19 PM
i know this sounds stupid. should i oil or not oil the foam on the stock air filter or would it be better to not use it???
Old 11-27-2008, 03:23 AM
what do you mean pre filter?
then yes but the paper filter no dont you will ruin it.
Old 11-27-2008, 03:28 AM
Infidel
Ditch the stock air box and go with a DIY set up.
Craig
Old 11-27-2008, 09:12 AM
i bought a afe stage 2 filter kit and love it easy to install about and hour hardest part was screwin in the air temp sensor on the bracket they give you because theres dirt in the threads
Old 11-27-2008, 09:17 AM
i run napa gold not 8 more than that forget cause i also grab a 5 gallon pale of oil so i dont no the prce of the filter i think 12 not sure
Old 11-27-2008, 12:28 PM
Send a message via AIM to Maverick1701
the stock filter is crap....it leaks A LOT and you will probably end up dusting your turbo if you run it long enough (but there are always exceptions....some folks run the stock box for 600K miles and have no issues).
A DIY setup is definately superior to the stock box...more air, less dirt, less dust, and it lets the turbo really sing w/all that air moving through
Old 11-29-2008, 10:00 AM
I dont the foam I thought was just to catch the bigger debri
