Any One Heard of this? - Ford Powerstroke Diesel Forum
Old 11-25-2008, 09:10 PM
Yep, its a 6.0
changing the stock coil springs out of a 97 F-250 and installin taller coil springs...i would like just about three inches of lift for the front
Old 11-26-2008, 06:03 PM
Yep, its a 6.0
bump............
Old 11-26-2008, 06:05 PM
Why just in the front
Old 11-26-2008, 07:51 PM
COON hunting
Old 11-26-2008, 08:13 PM
Yes you can install taller springs. I am not sure if you can get 3 inces but I know you can get two. You would just have to have the alignment cams installed to get the tire leaned back in. JJ
Old 11-27-2008, 03:29 AM
ant the 250's known for when you lift them the ties lean in because of the idepend axle?
jw
Old 11-27-2008, 04:41 AM
jw
Yes, But a chamber kit will fix it. Any IFS system does it.
Old 11-27-2008, 08:25 AM
A 97 f 250 does not have coil springs!!!
Old 11-27-2008, 08:28 AM
A two wheel drive does.
Old 11-27-2008, 08:31 AM
opps my bad
