rear spring hangers
my rear spring hangers on my 96 f250 are in bad shape as in rusted, ive got a new set of them to put on. has anyone else had this same problem and does anyone have any suggestions on the best way to replace these?
Well they are riveted on from the factory and the way I've always removed rivets like that is to use a grinder with a cutting wheel and cut an X in the head of each rivet then use an air chiesel or hammer and chiesel to finish removing them
that sounds easier than drilling them out
The shop had to replace mine for inspection. I guess they ground off the head of the rivets and bolted on the new ones.
Also when I installed mine I drilled a 3/16" hole in the bottom to let water and debris drain out ![]() Later, DEVLYN |
Later, DEVLYN[/QUOTE] GREAT TIP RITE THERE!! |
ya ill have to drill a drain hole in mine too when I install them
