HPOP
I assume a hpop from a 03SD 7.3 would be the 17* Can someone explain the advantage of one of these on a 97 7.3?
psd
17degree hpop is a sd hpop 2000sd.more oil more fuel more top end,better mpg.are you looking for one?a must have with a chip.
I work at a Ford dealership so i can get one pretty cheap just wondered what the benefit was, and waht year pump I should get
Psd
SD 2000 pump will do.
Highly recommend!!!
especially if you have/will have larger injectors...
yeah any 7.3 2000 (maybe 99.5 also) up will have a 17 degree pump. They flow more oil/pressure.
whats a ballpark figure on what these things run? is a rebuild ok or is it just a bad idea?
Dealer cost is around $550.00 with a $150.00 core charge
You can get them from international for 400 +/- for a reman. You can also find them on ebay for 200 ish every once in a while..
