EBPV closing when HOT - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-18-2008, 07:45 PM Thread Starter
metallitera's Avatar
My chief has the exact same truck as me except its auto and has about 190,000 on it. this morning at shift change he showed me....
his truck was at operating temp (R in normal), and idled fine, but when the engine reved to about 1200-1300RPM the EBPV kicked closed, RPMs dropped about 300 or so, and the valve seemed to stay closed at ANY RPM above 1200-1300. was only about 45 degrees this morning.
-ReD
Fire Lieutenant/Paramedic, Tinkerer
1990 Jeep Wrangler YJ
metallitera is offline
post #2 of 13 Old 11-18-2008, 09:31 PM
ZachBoyer's Avatar
Get rid of it. I think that there is a sensor somewhere that goes caputs but not sure I have mine open full time now
EBPV question
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #3 of 13 Old 11-18-2008, 09:43 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
ya, I unplugged mine....
Facing your truck with the hood open, it's under and to the right (driver's) side of the turbo. It's a two-wire plug. Unplug it and you're done.....easy as pie
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #4 of 13 Old 11-19-2008, 11:23 AM
hangnail's Avatar
what is the negitive effect or pro/con of doing this?
1997 F350 reg. cab 4x4 PSD
hangnail is offline
post #5 of 13 Old 11-19-2008, 11:47 AM
I have heard that you will see longer/shorter warm-up times depending on the outside temp (I live in tx so I didnt see any change).
I have also heard of folks loosing some mpgs (around 1.5) after doing it, but once again I didnt see any change.
I found this info in a ford manual:
Exhaust Back Pressure Regulator
Exhaust back pressure is controlled to provide more heat to the coolant for cab heating when ambient air temperature is below 5C (40 F) and engine oil temperature is between -10 C (15F) and 83C (182F) during low load. At high load, high speed conditions, the back pressure system is disabled.
ChrisChris
post #6 of 13 Old 11-19-2008, 12:59 PM
Send a message via AIM to kx592
So do you loose MPG with unplugging it? I would think the motor could breathe better giving you better mpg's?...
1997 7.3 extended cab 8ft.
4" straight piped
DIY intake- 6637 filter
178K on the dash
Boost, PYRO, Trans temp gauges (auto meter)
33" nittos on stock height
kx592 is offline
post #7 of 13 Old 11-19-2008, 01:27 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
You actually gain MPG by unplugging it. I did it on my 7.3 and it only took about another 30 seconds to warm up
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 13 Old 11-19-2008, 01:34 PM
burmad69's Avatar
I cant seem to find the damm thing
1997 F-350 PSD CREW LONG BED, BANKS DOWN PIPE,CUSTOM EXHAUST,BANKS TRANS-COMMAND, EGT,BOOST,TRANS TEMP.FPR SHIM, GUAGES.PIAA DRIVING LIGHTS,MY CUSTOM INTAKE,DIY INJECTORS
My house is guarded by SMITH&WESSON 4 nights a week. You Guess Which Ones!
I DONT DIAL 911
burmad69 is offline
post #9 of 13 Old 11-19-2008, 01:38 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Here is a pic
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 13 Old 11-19-2008, 01:58 PM
Well i just unplugged mine...see how she does tomarrow...use this link for the pic bud EBPV question
4" straight piped
178K on the dash
kx592 is offline
