Electric power availability question
With the truck in my sig, I power nothing more than stock with the current electrical system. I dont know what the alternator puts out, or if it even says. What I want to do is add a 12v 250-400 watt pad heater to my veg filter and would like to know if I can do this or if I would need a high output alternator. I wouldn't flip the heater switch until after I have started the vehicle so the glows and all would be off. or shoudl i be looking at amps?
Also, what do I wire the heater to, a battery or the alternator? Is it ok to hook it to one battery only? Thanks! Last edited by ridiculously_necessary; 11-18-2008 at 07:03 AM. |
You should have no problem running your vegy heater. you can power it off the passanger battery. Iam powering 6 kc lights that way just use a relay and a fuse for protection.
fuse, good idea. ok, so any idea how much available power i have before i need an alt upgrade?
I think our alt puts out 180 amps,my 6kc light draw 150 watts each,have not had any problems running them.Have had them on the truck for two years now.
wow, thats larger than i thought. any idea what the truck uses stock?
