leveling kit
I just bought a leveling kit for my 96 f250 psd and I am wondering how hard it is to install one of these kits and what do to and not to do. does anyone have any suggestions for me?
what kind of leveling kit? and a spring or??
its a rough country 2 inch leveling kit, add a leafs spring kit
How much did that cost you?
The leveling kit wont be hard to do at all, all you got to do is undo the u-bolts which could be a pain to get loose if they are rusty then be sure to put c clamps on the leaf packs and tighten them down before cutting the old centering pin. Then after cutting the centering pin undo the clamps and put in the add aleafts then clamp them up again and install the new centering pin and putting the u bolts back on
Thanks get a re alignment. Its much easier than doing a full lift thats for sure |
Me and a buddy did it to his king ranch. Wasnt to bad just had to have a dang come-a-long to get everything to line up again. My rough country came with all new spring packs and it took a come-a-long to get everything under it to. Wasnt real bad tho
the kit cost me $80 total, sounds like it isn't real hard to do at all.
No its not too bad, just adding leafs is real easy, its when you have to install bigger crossmember brackets on a TTB with a lift that is a real pain, Ive had to do it twice
for some reason I don't know why, the stock front springs on my truck sit about an inch or two from the bump stops. thats why im installing a leveling kit on my truck.
I did the same leveling kit to offset the weight of a plow but I havn't aligned yet and it needs it
