glow plugs install - Ford Powerstroke Diesel Forum
Old 11-17-2008, 03:37 PM
glow plugs install
well i have my new glow plugs ordered and i got the motorcraft ones and i was just wondering if there is any thing i need to do special besides remove the valve covers, pull them out and put new ones in?
also looked but couldnt find any writeups on glow plugs either
i know it is pretty easy but i want to make sure i dont mess anything up
Old 11-17-2008, 03:38 PM
also are the motorcraft glowplugs bad about swelling ?
Old 11-17-2008, 03:39 PM
a truck
Motorcraft are the best to go with and should not swell, as far as anything special, not really. Just pop the covers off and all the stuff you have to take off to remove the covers then pull off the wire on top of the glow plug, undo the glow plugs with a 10mm deep socket take em out and put em in and thats it
Old 11-17-2008, 03:41 PM
alright
sounds as easy as i was hopeing!
Old 11-17-2008, 03:42 PM
Yep, couldent be simpler. Unless of course it were simpler I guess!?
Old 11-17-2008, 03:43 PM
lol that is true i recon
Old 11-17-2008, 04:30 PM
The Motorcraft GP's are made by Beru.
A semi-deep socket works better but a deep socket and then a piece of hose will also work.
Old 11-17-2008, 06:48 PM
Yea the hardest part is probably taking the old Glow plugs out because the deep socket will hit the rocker arm and you cant get the glow plug out because the socket hits the rocker arm. so you need to loosen it and then find a hose you can push onto the glow plug and unscrew the rest of the way because you cant get your fingers down there to unscrew it
Old 11-17-2008, 07:43 PM
It's super easy to do like the others said. The torque rating is 14 ft-lbs. for when you install the new ones.
Old 11-17-2008, 07:54 PM
scuffs *****
Send a message via AIM to Tyler
Hey PSD0389, I think I saw a video of your truck on youtube.
